Thread: New to TFP method. Water Balancing
    Jan 2012
    Mission, TX
    16
    I have a 12, 000 galloon plaster pool with a salt water generator. Any advise on what should be the optimum FC, PH, TA CH, CYA levels. Pool is in direct sunlight for most of the day.
    12,000 Gallon IG Saltwater, Blue Quartz/Glass Bead Plaster, Pentair Quad 80 Cart Filter, A&A Infloor Cleaning System, Pentair IC60 SWG, EASY Touch Control Panel with 4Button Wireless Remote, Pentair Inteliflo VS, Pentair Ultra-Temp 120 Heat Pump, FLOWVIS Check Valve & Flow Meter 2"
    Jun 2014
    15,153
    Re: New to TFP method. Water Balancing
    Hello and welcome to TFP. To answer your question, there are two pages we use on a constant basis:
    Pool School - Chlorine / CYA Chart
    To use these properly though, you must have the proper test kit of your own that can be obtained from TFTestkits.net. Every piece of advice you see on TFP threads revolves around the proper test kit. If you don't already have a TF-100 or Taylor K-2006, we hope that you will consider getting one soon. Look around, and if you have any questions let us know. Welcome!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Pat has let out the secret, all our information is in Pool School, so all I can say is welcome to TFP!
    Support the site
    Jan 2012
    Mission, TX
    16
    Thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi robdgonz,
    welcome to TFP.
    To add what Pat provided, I would like to introduce you to the ABC's of pool chemistry. Its a quick rundown of what the different water parameters are and how they play together.
    Also a handy little tool we have can tell you how much of something to add to the water in order to reach your recommened level.
    http://www.troublefreepool.com/calc.html
    enjoy
    Divin Dave,
