Thread: Liner wrinkles
    Jun 2015
    Wamego/KS
    120
    Liner wrinkles
    Noticing a few wrinkles starting to appear in the bottom of the deep end. What would cause that?
    25x16 rectangular in ground pool with vinyl liner (14,000 gal). Sta-Rite sand filter. 1HP single speed Max-E-Pro pump. Pool owner since 2013.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Liner wrinkles
    What does the bottom of the pool feel like by the wrinkles? Is it solid?
    Kim
    Jun 2015
    Wamego/KS
    120
    Re: Liner wrinkles
    Yes. It feels solid.
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Liner wrinkles
    I have no idea then. I was thinking you had something happen to the bottom under the liner.
    Okay thinking out loud here.........the wrinkles are only in the the deep end........is there any shifting anywhere in the pool? the walls? side to side in the bottom?
    Has there been any HUGE rain activity in your area? Has there been any erosion around or by your pool at all?
    Kim
    Jun 2015
    Wamego/KS
    120
    Re: Liner wrinkles
    I take that back. After feeling the myself the wrinkles are soft not hard.
    Jul 2012
    Tallahassee, FL
    30,510
    Re: Liner wrinkles
    The wrinkles are soft or the bottom/ground right under that wrinkles is soft?
    Kim
