Thread: How long is chlorine good for?
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I have some liquid chlorine left over from a previous summer in my garage. How long is the stuff good for? It's been in the hot garage, but out of any sunlight. Any degradation?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Jun 2015
    N Tonawanda, NY
    476
    Re: How long is chlorine good for?
    I'd bet it has lost some of its strength but have no idea how much.
    If your chlorine level isn't high then use pool math to see how much will bring it up 2ppm. Add that amount & see if actually goes up 2 ppm.
    16' x 34' vinyl in ground - 16,500 gal.
    Hayward EC-75 DE filter with Hayward 1hp Super Pump
    TF-100XL Test Kit with SpeedStir
    30,432
    It depends. There is a degradation chart somewhere on the forum but I can tell you you have VERY little left, if any.
    Too hot, too long
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Thanks I tossed it
    Jul 2015
    Burkburnett/TX
    57
    I would have used it. Can't see how it would hurt...would only cost a couple drops of reagents.
    Sean
    17X34 above ground painted concrete pool. 32" deep on the shallow end, 44" on the deep end. Sand pool filter.
    Mar 2007
    San Rafael, CA USA
    12,082
    As shown in this table, chlorinating liquid will degrade rather quickly in hotter temperatures. I'm guessing that over a year it might be at 3-4% at best. Mostly the chlorine degrades into chloride and chlorate (poor quality chlorinating liquid also degrades into oxygen gas).
