Thread: Question on pipe diameter exiting from Hayward through wall skimmer
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    image.jpgWhat is the correct pipe diameter for exiting at the bottom of the skimmer? Ours seems to be 1.25" but I've read where others have used 1.5" diameter PVC. The picture shows a dry fitting of the 1.25" pipe. Looks like the external threads of the skimmer is the point we need to join up instead of the internal threads...so, what fitting or coupling do I need?
    Intex Rectangular AG Ultra Frame Pool Set, 24' x 12' x 52" (8403 gal, well water)
    Intex Krystal Clear Saltwater System model number: 28663EG/54601EG
    Intex sand filter pump, 120V 1,600gph with GFCI
    Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer
    Aug 2014
    Anderson, ca
    28
    Re: Question on pipe diameter exiting from Hayward through wall skimmer
    The threads on the Hayward skimmer is 1 1/2 fnpt. I bought a 1 1/2 npt x 1 1/2 slip adaptor and ran 1 1/2 pipe. Looks like you have a 1 1/2 npt x 1 1/4 reducing adaptor.
    5061 gal AG Intex 16 x 48 Ultra metal frame installed 8/10/14. 1500 gph Intex Cartridge Filter Pump with over side skimmer. Intex SWG 7k gal. TF-100 Kit
    Idigress's Avatar
    Jul 2015
    Fort Worth, TX
    42
    Ah, makes sense. Thanks for responding
