Thread: Changing out bearings. Noisy motor.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hello All,
    Well my 2-speed motor starting making noises this week. The pump its self is a Sta-rite Duraglas PEA5D-180L/P2R5D-181L (Impeller C105-92PS Diffuser C1-216P) (Frankensteined to a 2-speed) Ordered a new shaft seal and bearings for my AO Smith SQL1072R. Motor was installed in summer of 2013.
    The shaft seal was $5 for a PS200 and the bearings 6203-2RS (ABEC3) were $6 for both ends.
    Hopefully the motor will come apart without too many issues.
    I'll try to take some pictures and post the results here. In case it takes longer than a day I've got a 3/4 single speed standing by.
    Jun 2015
    Wildomar, California
    423
    Re: Changing out bearings. Noisy motor.
    Do you have a bearing puller? Pretty useful tool.
    Apr 2011
    Murrieta, CA
    2,360
    I'm pretty sure I do. Autozone has them for rental
    Apr 2011
    Murrieta, CA
    2,360
    OK. Changed out the bearings. It was pretty easy overall.
    Here's the steps I followed:
    How To Replace the Bearings in a Pool Pump Motor - Part I - INYOPools.com
    How To Replace the Bearings in a Pool Pump Motor - Part II - INYOPools.com
    Had to stop 1/2 way through. Didn't have a piece of pipe (3/4 inch black or galvanized about 6 inches long (homedepot) and needed a snap ring pliers (autozone).
    Took me about 3 hours. The hardest part was that I overtightened the V-Switch on the back side and needed to adjust it and rebend the bracket. How To Adjust the V-Switch on a Hayward Super Pump Motor - INYOPools.com
    $12 bucks for parts. We'll see how long the bearings last.
