Thread: Add Muratic Acid and Wait to Aerate How Long?
    john.esher's Avatar
    Jul 2015
    Havertown, PA
    40
    So I went to pool school and determined that to lower my TA of 120, I need to lower the pH which will reduce the TA. I added Muratic acid in an amount suggested by pool math, and then right away turned my return jet toward the surface. I just measured pH and TA (about 5 hours after acid addition) and got roughly 7.0 and 120 respectively.
    Am I doing this correctly, or should I be waiting a few hours with the lower pH before turning the jet?
    Do my results seem appropriate and I just need to be a little more patient? Was hoping for a late afternoon/evening swim.
    Intex 18' x 52" AG with Sand Filter Pump & SWG (Model ECO15110) about 7,600 gallons tested with a K-2006-SALT.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,028
    Re: Add Muratic Acid and Wait to Aerate How Long?
    Hi John,
    you're doing it right. No need to wait on starting the aerating.
    As for testing, it takes about 30 minutes with the pump running to get a good test result. No need to wait several hours to test after you have added something.
    hope this helps,
    Divin Dave,
    38,546
    The TA and pH will lower at the same time when the acid is added. You can start aeration right away.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Aerate. Jump in, get the kids jumping in.
    Last edited by bobodaclown; 08-01-2015 at 04:31 PM. Reason: Corrected post. Deleted incorrect information.
    mas985's Avatar
    Pleasanton, CA
    11,743
    From Pool School:
    It is actually the acid which lowers TA. Adding acid lowers both the PH and the TA. Then aeration raises the PH without changing TA.
    TA does not fall with rising PH. Only acid reduces TA.
    Mark
