Results 1 to 7 of 7
Thread: Did I just hose my pH?
    Mar 2015
    Las Vegas NV
    460
    So I did the drop test per my taylor test kit to see how much I needed to lower pH by, looked-up in their table and it said roughly 40 oz of acid (liquid) to get to 7.5 (since it's a new plaster pool I like to take it to 7.5 knowing it will rise due to the new plaster, isn't it great doing your own testing and "knowing" your pool). So I eyeball about 40 - 50 oz of muriatic acid (29%) and add it to the pool. Come to my desk to enter my numbers into the Jesse's spreadsheet and it tells me to add 20 oz., so I go to pool math and it says 27 oz. So depending on which numbers I use I could have gone over by 100 - 125% in what I added. Did I just hose my pH?
    SUMMER 2015 BUILD IG gunite 38 x 31, 28,000 gal, 110' perimeter, Intelliflo VS, Whisperflow 3hp, Intellibrite LED x2, Clean & Clear 520, Screen Logic, Intelichlor 40, Quartzscape Blue, K-2006C, Speedstir, Aquanaut 400 (4 wheel The Pool Cleaner)
    38,305
    Re: Did I just hose my pH?
    Easiest to just wait 30 minutes and retest
    Retest in a little while. 40 oz won't be too much.
    What is the TA?
    Support the site
    Mar 2015
    Las Vegas NV
    460
    Thanks!
    Quote Originally Posted by JamesW View Post
    What is the TA?
    90
    Acid demand should be fairly accurate. In any case, 40 oz won't be excessive for your TA and pool size.
    Support the site
    Mar 2015
    Las Vegas NV
    460
    UPDATE: Tested about 1:30 later and I'm between 7.2 - 7.5 pH.
    Raining like crazy right now (yea it rains in the desert), while I have you, does rain do anything to the water balance, anything I need to look for after the rain storm blows through?
    38,305
    Rain should not affect much. Just test and adjust as needed.
