Thread: Help switching from Perma-Salt
    gksipple's Avatar
    Jul 2014
    smyrna. tn
    11
    Split by moderator from HERE. jblizzle
    Welcome to TFP!!!
    Sorry, you were sold a bunch of bogus information and a system we do not recommend. Search the forum for "permasalt" and you will find plenty of reading.
    We just do NOT recommend the use of metals in a pool due to the risks of staining and green hair.
    BTW, we would not recommend just throwing in some Trichlor pucks either.
    Have you discovered Pool School yet? Start with these so we are speaking the same language:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    You still have a chlorine pool ... and the maintenance on that is the same. You just have a bunch of copper in the water also.
    Same thing happened to me, and Im not a happy camper at all! I bought this because I didn't want to do a chemistry experiment every time I wanted to swim. Heck I barely scraped by Chem 101 in college and that was eons ago.. System worked fine for about 6 weeks, but now all of a sudden the water is cloudy, no..opaque! I went to the store where I purchased the pool, had water tested, and they told me the phosphate level was high. Phosphates?? So I bought a $50 dollar a bottle phos-free to fix it. After 2 treatments..STILL opaque! Wised up to F-L's game and went to the local pool store, and got these numbers:
    FC 0.52
    pH 7.5
    TA 78
    CH 70
    CYA 1- I'm not kiddin'
    Cu 0.5(apparently a nml level according to F-L.)
    I am frustrated, and angry, and feel like I got scammed. Just don't know what to do next. Will have to endure this POS system until the yr warranty runs out, but after that, I'm makin' a change. Just not sure which way to go. Any responses are appreciated. THX.
    gksipple
    18ft Seaside 52" deep AG, 26" Ecolife Sand Filter, Waterworks 1.5 HP, Permasalt POS. (guess you can tell where I got ripped off now)
    Mar 2015
    Harvey, LA
    300
    Re: Perma salt system.- levels all over the place
    Is the warranty dependent on you using the permasalt system? I would think if that's true, then they are required to provide you chemicals free of charge...at least that's how it works with car warranties in the same idea...
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    gksipple's Avatar
    Jul 2014
    smyrna. tn
    11
    I believe that with this particular company, that if I didn't use the prescribed chemicals specifically designated for the Permasalt system, that would void any warranty. Not sure, but I don't really want to take that chance in case something really really major happens.
