Results 1 to 8 of 8
Thread: Do round "solar discs" really help heat a pool?
    Jun 2015
    Atlanta, GA
    640
    We have a long narrow lap pool and cannot imagine dealing with a long bubble wrap type solar cover. Do the round disc-type panels actually work?
    12K Gallon IG Lap Pool (c. 2001)
    6.6 ft x 48 ft/White Plaster/Concrete
    Pentair Superflo VS Pump 2.0 HP/Sand Filter
    Dolphin S300i Robot/SolarBreeze Robot
    TFT-100 Test Kit
    Jul 2015
    San Diego California
    10
    Re: Do round "solar discs" really help heat a pool?
    Quote Originally Posted by AmyJo View Post
    We used to have them before we went solar and they heated our pool about 5-7 degrees more. They really helped with evaporation. Some issues to consider:
    -you need many, about 80% plus of your pool
    -they warm the surface more than the bottom
    -they get dirty and do make it a bit difficult to skim
    Overall worth a few hundred dollars.
    Jun 2015
    Atlanta, GA
    640
    Thank you Drmtesta. I had not even considered how difficult cleaning might be. However a 5-7 degree change in temperature would be wonderful.
    TFT-100 Test Kit
    38,248
    Covers do not add heat to the pool. They retain heat by reducing heat loss due to evaporation and radiation at night. Therefore the more you can cover, the better. Many threads discuss these rings with far from great feedback. They are expensive and have a tendency to move and pile up is there is wind.
    Donldson's Avatar
    NW Ohio
    2,881
    I stopped using them. They bunch up in the wind and are a pain to put on and remove. The biggest annoyance, as mentioned above, is that non-chlorinated water pools on top of them. This causes plenty of algae to grow. So when you take them off you get algae and other crud falling in to the pool.
    They just became far more of a pain than they were worth.
    From my HTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jun 2015
    Atlanta, GA
    640
    Yikes. Thank you all for your feedback! I guess I will wait to have solar installed!
    TFT-100 Test Kit
    30,403
    Amy, this post is a classic example of the benefit of keeping your post under one thread. I have seem pics of your pool in that thread so I know what you are talking about. A solar cover (one piece) would be perfect for that pool and easy to manipulate but the rings would be a PITA.
    Jun 2015
    Atlanta, GA
    640
    Duraleigh - I apologize. I thought it might be easier than reading through a long post. Duly noted!
    TFT-100 Test Kit
