Results 1 to 8 of 8
Thread: Took over with TFP - am I on the right track?
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Tested today after instructions from here yesterday as a result of pool company handling chemicals for first month as part of warranty.
    Here is where I am out - keep in mind I'm swg.
    August 1
    FC 3.5ppm
    CC 0.5ppm
    Total chlorine 4.0ppm
    CH100ppm
    TA 80
    CYA 45
    New Build started April 2015, 20x30x40 Lagoon Style Vinyl (indigo marble/blue granite), 27,500 GAL, IG, 839 square feet, 9' tanning ledge/baja shelf, 9' radial bench, 8' classic Waterfall, 3'6" to 8'Depth, Sand, Pentair 2 speed Superflow 1 1/2 HP, SWS, 2 Pentair LED Intelibright 5 G lights, Pentair Legend Platinum II pool cleaner, 2 skimmers, 3 returns. 1080 square feet of Silver Slate stamped concrete.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Took over with TFP - am I on the right track?
    CYA needs to be at 70- 80 for a SWG.
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    It takes up to a week to register right and just added yesterday so I thought getting up to 45 by today was progress should I do more?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Quote Originally Posted by karynkjd View Post
    did you measure and only add a specific amount with a target CYA in mind?
    Support the site
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    I did the calculation on Pool Math and it was around 110 oz into skimmer in sock. It still isn't going up...
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Do I have to increase the CH also? Going to test again tonight after running the SWG full time for three days and see if the salt went down and where the chlorine is at this point. Supposedly the PB came over yesterday to look at the pool/salt generator. He said the pool had too much salt. hey thanks Captain Obvious, you're the only ones who put salt in. He claims no issue with equipment so - will update tonight. Took some ideas from sunbaby and made a little notebook with reminders and what to use on pool.
    Wish me luck
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Wish me luck
    Vinyl pool doesn't need Calcium since there's no plaster to etch. If you see foaming above the returns, raising CH should stop it, but it's not harmful, just annoying. CH will naturally rise with evaporation, too.
    Salt will only go down by splashout or replacement. If the SWG isn't showing warning lights, leave it alone. If it's happy with the salt level, you should be, too.
    Just assume the CYA you added is there and target FC accordingly. Test it again next week and see where you ended up.
    karynkjd's Avatar
    Mar 2015
    Berlin, NJ
    325
    Sounds like a good plan. Thank you so much. The pool is clear for sure just not crystal clear so maybe as the cya rises it will inprove
