Results 1 to 10 of 10
Thread: Hayward filter
    May 2009
    Trenton NJ
    497
    Hayward filter
    Back washed last nite. Noticed I had some sand on the ground after. Not a lot but some. Problem?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Jun 2015
    Wildomar, California
    423
    Re: Hayward filter
    Could be. Was your sand bed level to high, or did you recently change the sand? If not, then you start thinking about broken laterals etc. Usually if something is broken in your filter, then sand will return to your pool.
    May 2009
    Trenton NJ
    497
    Re: Hayward filter
    The filter is about 5 years old and I never changed the sand. When back washing would the sand come from the pool or the filter?
    Where do I go from here? Can I repair it or do I need a new filter?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Hayward filter
    A little sand out the backwash is no big deal. During a backwash you're agitating the sand pretty good and it's going out the in pipe which doesn't have laterals to stop it.
    If the sand is going into the pool, the next question is did you rinse?
    May 2009
    Trenton NJ
    497
    Re: Hayward filter
    Yes I always rinse. It has been awhile since I back washed. Also is 5 yrs .....old for sand? My pressure holds pretty steady at 15 psi n water looks good/ clear.
    Richard320's Avatar
    Jan 2010
    19,037
    Re: Hayward filter
    Your sand is already a few million years old. 5 years is nothing.
    May 2009
    Trenton NJ
    497
    Re: Hayward filter
    So nothing to be concerned about?
    Jun 2015
    423
    Re: Hayward filter
    No, it doesn't seem like a major issue.
    May 2009
    Trenton NJ
    497
    Re: Hayward filter
    Thanks
    Jul 2015
    Addison/IL
    4
    Re: Hayward filter
    Have a very similar filter/problem over here. Was getting a little bit of sand shooting back into the pool after backwashing and rinsing. Was going to let it go until next season, but my skimmer was leaking, so had to drain anyways. Used the stickied hose cleaning method for about an hour and got a whole bunch of junk out, then realized my pvc pipe leading to my laterals has a crack running down it. Now I'm going to order a new pipe and laterals and probably get some new clean sand in there while I'm at it. One problem just leads to another. Hope your Heyward behaves better than mine.
