Thread: Above ground pool lighting
    May 2015
    Brooklyn NY
    46
    Hello everyone. I am thinking of installing some underwater lighting into my pool. After lowering my water below the level that I want to install the light, is it OK to drill a hole through and area other than the steel part that the skimmer and return is hanging on? Thank you
    Salt Water 8000 AGP 12' X 18' X 54" - Hayward S166T 16" Sand Filter w/ 1.5HP Power-Flo Pump - Hayward Aqua Trol RJ Salt Generator System
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Above ground pool lighting
    They make magnetic stick on lights that you might look into in case you didn't know. Also check into the Nightlighter.
