Last season when I closed my pool I noticed the pump was a little loud. This season when I opened the pool it sounded like a jet engine! I ordered a bearing/seal kit/puller kit from Wethead. When I removed the pump from the plumbing I noticed that 3 of the 4 through bolts were broke. I got the pump inside and tore it apart, marking everything so when I put it back together everything lined up in its original spot. Got the new bearings and seals put in it. Went to my local pool store, they had a junk motor and gave me the through bolts off of it, they looked brand new. Put everything back together, but I was only able to use 3 of the 4 through bolts as the 4th one was broke off in the housing and I couldn't remove it. Reconnected the pump to the pool plumbing and flipped the switch... it hummed but nothing happened. After about 1 maybe 2 seconds I turn the pump off and walked away mad. The next day I went out to take the pump back out of service and thought why not try it one more time. When I turned the pump on it took off and ran like a champ instantly. The pumped worked for about a week when one day I went out and cleaned the pump basket out. I put everything back together as I normally do and restarted the motor. The housing was about 1/2 full of water when I turned the pump back on. The pump primed and was full of water within 30 seconds. After running for about 1-2 minutes the pump changed noise and when I looked at it, it began to smoke. While it was smoking it was still pumping water strong. Not sure what to do I again walked away. The next day when I flipped the pump on it started running like normal but instantly started smoking so I turned it off. I can't really tell where the smoke is coming from b/c it happens so fast and it surrounds the pump. I checked all the supply, return, and vac lines and nothing is clogged. All my equipment is in a vented mini barn/shed with a concrete floor about 4' from the deep end. I would like to try and fix this before having to buy a new motor. Any idea as to what is going on?
