Results 1 to 7 of 7
Thread: reccomendation to balance salt water pool
    Jul 2015
    Lake Elsinore, CA
    9
    CYA: 90
    FC: 7.5
    PH: 7.6
    CC: .5
    TA: 200
    CH: 725
    Tested with Taylor K2006.
    I just went up to my moms house for the weekend. She has a pool man that does her pool.
    I brought my test kit to see how good he is doing.
    I am curious are these numbers bad for a saltwater gunite / plaster pool with salt water generation?
    CH seems really high.
    What would y'all do to balance.
    I think maybe lower CH to 400 and TA to about 90?
    What will high CH do to plaster?
    Intex 9 x 15 x 52" 5000 gal, vinyl, Sand filter pump, Taylor K-2006
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: reccomendation to balance salt water pool
    The only way to lower it is by draining some water and refill with lower CH. The CYA is a bit on the high side too. I don't know exactly what the fill water test like, but my guess is the pool would benefit from a drain and refill of about 20%. That would lower the CYA to about 70 and hopefully bring the CH down to a more reasonable number. The TA is also very high, and my guess, since it's a SWG pool is its difficult to keep the pH from getting too high, which if not controlled would cause scale.
    chiefwej
    30,426
    +1 what chiefwej said
    I have a SWG pool; 20 K gallons, in ground, gunite. Where I keep it:
    FC - 1 to 5 ppm
    pH - 7.4 to 7.6, no higher than 7.8
    CH - 175 - 400 ppm
    TA - 80 - 120 ppm
    TAc - 50 - 80 ppm
    CYA - 70 - 80 ppm
    Salt - 3000 - 3500 ppm
    My pool is in it's third season, it has never been out of LSI balance.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by joeyparrot View Post
    FC - 1 to 5 ppm
    CH - 175 - 400 ppm
    TA - 80 - 120 ppm
    TAc - 50 - 80 ppm
    CYA - 70 - 80 ppm
    I assume you mean CSI not LSI. You need to raise your FC target. With a CYA in the 70 your FC range should be 3 to 5, and with CYA of 80 it should be 4 to 6.
    chiefwej
    Jul 2015
    Lake Elsinore, CA
    9
    So we swam in my moms pool with the results posted above. Had some skin irritation and burning ing of the eyes. a little late but was it safe to swim technically.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    The CH is high. Given hard water and probably a lot of evaporation where she is, I'm not at all surprised.
    If you plug those numbers into poolmath and change things around, you will see that lowering the TA is the easiest way to lower the CSI.
