Thread: Adding a slide
    Jun 2015
    Ottawa/Ontario
    339
    Adding a slide
    Hi all
    We have a 7 ft deep pool in the deep end, 3 ft in shallow. It is an 18x36 irregular shape IG pool. It is not a diving pool, but curious if there would be any issues with adding a slide...
    Thoughts?
    90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Adding a slide
    Check with your home owners insurance before you get too far into things, some object to slides, some object to diving boards, some object to both, a few don't seem to care.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Adding a slide
    Slides generally require min 3 feet of water at the wall and 4 feet 12 to 15 feet out. You need to check the specific requirements for the slide you want.
    Read this:
    Adding a Pool Slide to your Inground Pool
    Also find the installation instructions for any slide you are considering and make sure you can meet the requirements in the instructions. What will your water source be? Can you tap into a return? Using a hose adds water to the pool fast.
    Call me when you get it done I get to go first.
    Jun 2015
    Ottawa/Ontario
    339
    Re: Adding a slide
    Thanks both! Very helpful.
    Aug 2014
    Shallotte, NC
    693
    Re: Adding a slide
    Just our experience, but we had homeowner policies cancelled twice, because we had a slide AND a diving board.... and that was BEFORE we got to closing!
    Jun 2015
    Ottawa/Ontario
    339
    Re: Adding a slide
    Wow. Scary stuff. Ok - nixing future slide thoughts - glad i didn't mention anything to the kids!!!
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
