Thread: Plumbing help for summer escapes pool sand filter upgrade
    Jul 2015
    Marion in
    8
    Exclamation Plumbing help for summer escapes pool sand filter upgrade
    I have a small summer escapes pool. Filter went out. So I decided to do an upgrade. The new hoses on this intex Krystal clear filter are to large for our current inlet and outlet on the pool. What do we need to do to get this to fit? Any help would be appreciated.
    Jul 2015
    Marion in
    8
    Re: Plumbing help for summer escapes pool sand filter upgrade
    I know they sell conversion kits. Our dilemma is the hoses seem much bigger than the inlet and outlet. Will it be sucking really hard to get the water in and out. Is their any way we can change the inlet and outlet pieces? Anyone know? The hose is 1 1/2. The inlet and outlet is much smaller.
    Jul 2015
    Marion in
    8
    Here is some more pics.
    dakhath's Avatar
    Jul 2015
    Central FL
    35
    Have you measured the pool fittings? The Intex hoses that came with the filter are 1.5 inch hose. I'll bet that the pool fittings are the smaller 1.25 inch size.
    If that is true you can try these. You'll need two of them.
    It would be the easiest and most simple fix for you.
    These are made specifically to do what you are trying to do.
    It wouldn't require any more additional parts to get you up and running.
    http://www.intexcorp.com/10722.html
    Coleman 5300 gal 16'x48" AGP
    Intex Krystal Clear 2800gph Sand Filter Pump 28647EG (56673EG)
    Intex Krystal Clear Saltwater System ECO 8110
    Taylor K-2006 & K-1766 test kits w/ Speedstir and Samplesizer
