Results 1 to 12 of 12
Thread: Speeding through bleach
    I am going through 2 gallons of bleach a day in my 21200 gallon AG pool. I had a little algae a couple of weeks ago. I shocked the pool and now my pool is crystal clear. However everyday, my FC reading is around 2 and I bring it up to 7.
    All of my other readings are good, CYA is 40.
    Is this normal?
    Eddie
    30 foot round pool. 4 feet deep.
    21,200 gallons
    AG
    Sand filter
    Taylor FAS-DPD Testing kit
    Jun 2014
    15,221
    Re: Speeding through bleach
    Eddie, 2 gallons a day for your size pool is not normal. FC gets lost from two ways: the sun or algae/organics in the water. Your best option right now is to raise your FC to SLAM level or at least an FC of 10 and perform an OLCT. If you pass the OLCT, then you know it's the sun and perhaps CYA needs to be adjusted. Seeing however that you had algae recently and merely "shocked" the pool, it's very possible you never really completed or finished a true TFP SLAM.
    - Do the OLCT first; if you fail, it's confirmed - SLAM. See the links in my signature for specific information to help you SLAM.
    Let us know if you have any other questions. Good luck!
    Aug 2013
    Arab, Alabama
    422
    If you are using 8 ppm/day I would consider that an elevated usage. Have you performed an Overnight Free Chlorine Loss Test (OCLT) and what type of test kit are you using?
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    It sounds like you beat the algae back, but did not eradicate it. This is why we do not shock pools, but conduct a SLAM which is a process based on testing to prove that everything growing in the water is dead.
    Time for a little Pool School and reading up on the SLAM.
    Support the site
    Slam is what I did. I said shock but it was a slam. I brought the FC reading to 24. However I didn't do the overnight test. I don't understand why the pool is so clear, algae is gone but it still needs so much bleach.
    I think I slammed the pool about 8 says ago to be exact and there isn't any traces of the algae that was in the pool.
    Eddie
    21,200 gallons
    AG
    Sand filter
    May 2014
    Franklin, NC
    9,193
    Quote Originally Posted by EddieO View Post
    Eddie
    The algae is not gone - just bringing the FC level to shock is not a SLAM. You must maintain FC at shock level until all 3 criteria are met
    Clear water
    Less than .5 CC
    Pass OCLT
    If you don't pass all three you run the risk of a low level algae colony staying in the pool. You may have clear water, you can't see the algae, but it's there. The chlorine is trying to get it, thus the high consumption level.
    Re-read the SLAM directions and follow them to the end. It will eradicate the algae.
    Support the site
    Ahh I see. I'll slam it again. I have bags of shock in my garage. Can I use that or should I stick with bleach?
    Eddie
    21,200 gallons
    AG
    Sand filter
    Never mind. I found my answer. Don't use Dichlor.
    21,200 gallons
    AG
    Sand filter
    Sep 2014
    Fort Lauderdale, FL
    146
    That's not a hard and fast rule. With a CYA of 40, you could still use dichlor if you wanted to bring your CYA a little higher. I'm perfectly happy running mine around 50-55, since my pool gets a ton of strong sun exposure. It's just a question of how low or high you want to maintain your level.
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    May 2014
    Franklin, NC
    9,193
    if you would update your profile with your location it would help us give more specific answers. If you were in Ft Lauderdale like Jeff, then higher CYA might not be the end of the world and you could use some dichlor, but if you are in Vermont I would say stick with 40.
    I run 50 here in the center of SC.
    Support the site
    BobbyR's Avatar
    Jun 2013
    Toronto, Ont
    142
    Trust these guys when they say there's algae lurking in your pool. At 2 gallons a day with CYA at 40 there's no other explanation. You'll know when the last of the algae is eradicated because chlorine demand will suddenly just drop from one day to the next. My pool is a bit larger than yours and gets full sun for much of the day and I use less than half a gallon of 12% a day.
    Lagoon 40x22, Vinyl, 27,000 gal, 1HP WhisperFlo Pump, Pentair 60 gpm Sand filter, Hayward Brominator (used for chlorine pucks only when away), Rheem gas heater, Dolphin M4 Robot
    Waterfall on separate dedicated pump
    Apr 2015
    South Central PA
    298
    I looked at pool math and it says to go from FC=2 to FC=7, you need 157oz of 8.25% bleach. This is 1 gallons, 1 quart....Not trying to nit-pick, but saying you're adding just over one gallon/day may change people's answer. Or if you are adding 2 gallons per day, are you going to an FC=10?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
