Results 1 to 7 of 7
Thread: Repairing a PVC pipe valve junction leak
    Delmar, NY
    3
    I was wondering the best way to repair a leak at the junction between PVC pipe and the intake valve (cold) to the heater. Besides replacing the pipe and valve, does anyone have any experience with a product called Plast-aid? Here is the link with some information: Plast-aid pool & spa repair. I was also considering an Epoxy pool putty, any advice is truly appreciated.
    Frank
    30,419
    Is the junction threaded?
    Delmar, NY
    3
    Not sure if it is threaded, is there a way to tell?
    Frank
    30,419
    Frank,
    I'm pretty sure it will be threaded. A pic would confirm. If it's a threaded joint, you simply need to unscrewit and put some pipe dope or teflon tape on the threads and screw it back in.
    DO NOT use epoxy or any other permanent adhesive on a threaded joint. It's an easy fix and one you can do yourself.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by frankc
    Frank
    Usually a threaded fitting will flats molded in around the edge so that you can get a wrench on them to turn, or will have some other type of grip-type surface that you can grip with your hand (or a pair of slip-joint pliers, if necessary). non-threaded fittings are usually smooth sided, because once you glue it, there isn't any need to try to turn it.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Delmar, NY
    3
    I do think its threaded, currently at work and can't confirm...Thanks to both for the input, will let you know how it goes.
    Frank
    Mar 2007
    Coastalish 'down easter'
    4,160
    Frank, many of these are 'unioned', if yours is, make sure that the o-ring or gasket is in good shape
    Luv& Luk
    -Ted
