Thread: Salt Pool Chem Balance Question
    Jul 2015
    Clearwater, FL
    83
    I have been slowly learning my newly resurfaced pool. We filled it in May, and TA has finally come down. pH is stabilizing, needing only small additions of muriatic acid every few days. Despite all the torrential rains that have had me dumping more than a foot of water over the past month, I think I have CYA where it needs to be (barring too much more water exchange). Calcium hardness has been dropping a little, though. Do I need to be concerned with CH right now? I know that after a couple dry weeks I may have to add water, which will bring CH up some.
    My numbers from the Taylor 2006:
    FC 5.5. pH 7.8 (lowering it to 7.4 today). TA 60. CH 230. CYA 70. Salt 3000.
    I measured less than 0.5 CC today, which seems to be the norm with clouds, storms, and lots of tree debris in the pool. Usually there is no CC.
    16K gallon IG exposed aggregate pool with Aquarite SWG T15 cell, Hayward C1750 filter, EcoStar SP3400VSP pump, H400FD pool/spa heater, Polaris PB4-60 booster pump, 280 pressure cleaner, Hayward Super II spa pump and Air Supply Silencer spa blower
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Salt Pool Chem Balance Question
    Thomasg,
    Welcome to the forum. Have you tested your fill water for CH? 230 is a little low. I run mine around 300. It should not be a problem in the short term but I would not run it that low for an extended period as it will leach calcium from your plaster. Your other numbers look great but your TA looks a little low. I run my TA around 70 which is on the low end but it helps keep my Ph a little more stable. Good luck!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jul 2015
    Clearwater, FL
    83
    Thanks, ComputerGuyInNOLA. Haven't tested fill water for CH, but I will if I have to do any significant filling. Right now my problem is too much rain. Early next week should be dry, so I'll probably address CH and TA then.
