Thread: Pentair Buttress Thread Closure Replacement Kit?
    Jun 2013
    Dallas, TX
    105
    The top of my pentair sand filter is leaking, so I purchased a thread closure replacement kit.
    The instructions are unclear on what I need to do when replacing.
    -Do I use silicone on the rubber gasket?
    -Do I need to use pipe dope on the clear top piece that screws in (houses the pressure release and gauge)?
    -Anything else?
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: Pentair Buttress Thread Closure Replacement Kit?
    I haven;t got a clue, but I'll give you a in case someone else does.
    Use silicone lube on the o-rings.
    Note that there are two types of threads. There is a "V" thread and a buttress style thread. The "V" threads are triangular, whereas the buttress thread is flat on one side and angled one the other. They are not interchangable.
    Triton filters manufactured after After Dec. 1, 1991 use the buttress style.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Gotta ask, Dagobah. Are you a Star Wars fan with a name like that?
    Jun 2015
    Wildomar, California
    423
    Use silicone lube for the orings and top fittings, although you can also use pipe dope and Teflon tape as well
    Jun 2013
    Dallas, TX
    105
    Quote Originally Posted by JamesW View Post
    Note that there are two types of threads....
    Thanks a ton. This appears to be a '01 so I should be good.
    Quote Originally Posted by MarianParoo View Post
    Hah, yup!
    Quote Originally Posted by OldPoolMan View Post
    Thanks! Super easy fix. Replaced the part in 5 minutes, all seems to be running with no leaks.
