Thread: New PB - pump with future solar
    May 2015
    Land O Lakes, FL
    527
    I am currently getting quotes for a new build . what do I need to be looking for in regards to a pump that will support solar on a two story home.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New PB - pump with future solar
    There are very few solar pumps on the market, most that are out there use DC permanent magnet motors and DC power straight from the solar panel with no loss for converting to AC or storing in a battery. The advantage of this design is the pump will speed up and slow down depending on the amount of sunlight. The downside is they are hard to find in North America, there have been importers in the past, but I don't know if anyone is importing them now. The other downside is since they are generally from Europe, the pumps tend to have metric fittings and metric to US standard pipe adapters.
    Jun 2015
    Ottawa/Ontario
    336
    Lorentz is a german company with distributors across NA. We use their PS 600 pump and C17.1 MPPT controller - it runs exactly as Isaac-1 states - it is also a 3 phase motor. There is also a company in California called SunPumps, but i have no experience with them.
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    If your question assumes you will use your pool pump for powering the solar, I would recommend a variable speed pump with sufficient power to satisfy all current and future needs. I'm using a Pentair Inteliflo VS 011018 (3 hp) pump. At low flows (1,000 rpm) it draws about as much power as a single 100 w light bulb, and can be ramped up to provide as much power and flow as you are ever likely need. It cost a bit more up front, but provides a lot of flexibility and potential energy savings.
    chiefwej
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by tlevy View Post
    Nice find, just found that pump in florida :
    Lorentz_PS600 CS-17-1 | Florida Solar Pump
    PS600 CS-15-1, Lorentz Solar Pool Pump System - DC Solar Pool Pump | Florida Solar Pump
    http://www.floridasolarpump.com/wp-c...s_ver30132.pdf
    Jun 2015
    Ottawa/Ontario
    336
    Do the math on your utility bill - it will be a larger upfront cost over a normal AC pump, but could pay off within 10 years....our Lorentz is tied to 1.5 kW of solar panels.
