Results 1 to 12 of 12
Thread: Solid pool conditioner question
    Jul 2015
    Eaton Rapids
    41
    Hey all,
    I'm going to start raising my CYA level tonight and I have some questions.
    I thought I was going to be using liquid stabilizer but ended up needing to buy solid pool conditioner.
    I've been told that I need to put it in a sock and put it near my "return". Is that my skimmer basket? Can I start shocking my pool tomorrow if I start the conditioner tonight? I need to get from 0 to 30 and I've done the pool math and basically I'll need 2lbs of solid stabilizer. I'm also assuming I run my filter during this time. I think I'm just going to leave it over night and then start the shock process tomorrow. Is that going to be OK?
    Thanks, I'm sorry I'm such a n00b at this
    7600 gallons AG. Hayward Sand filter. Taylor k-2006.
    Jun 2014
    15,008
    Re: Solid pool conditioner question
    Hello! Yes, we typically place the solid form (granular) stabilizer in a sock. Some place it in a sock near/in the skimmer, but I would venture to say most simply hang the sock near a return jet with the pump running. You can squeeze the sock from time to time to help disperse the stabilizer. Remember it will take about a week to show-up on yore CYA testing. Once added, consider it in there at the level you projected and start your SLAM whenever you need to.
    30,403
    No the return "returns" water to your pool. The skimmer intakes water that goes up to the pump. Many put the conditioner in a sock and throw it in thje skimmer because your pump will run 24/7 during the SLAM.
    read "SLAM" in the "How To" section up in Pool School.
    Jul 2015
    Eaton Rapids
    41
    When you say "skimmer" you mean the basket that it's in my pool correct? I can just put the sock in or near that?
    Earl Cox's Avatar
    Jul 2015
    Lexington Park MD
    314
    Yes that is correct in the basket
    6280 Gal Intex 17' x 52" Metal Frame AG
    2500 GPH Filter Pump
    Intex Krystal clear SWG
    Taylor K-2005 With FAS-DPD Drop TEST KIT And Speedstir
    Intex Robot Pool Cleaner
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    I have short pieces of pool noodle that I tie it on to and just let it float around the pool, squeezing whenever I'm near it.
    Jul 2015
    Eaton Rapids
    41
    Quote Originally Posted by YippeeSkippy View Post
    I'm curious what's the point of putting it in the sock?
    Also do you squeeze the sock while it's in the water or take it out first?
    Jun 2014
    15,008
    Squeeze sock while in the water. It helps get the powder out nicely. Having the granules in the sock prevents them from getting sucked-up into the filter and possibly washed out too soon before they dissolve.
    Jul 2015
    Eaton Rapids
    41
    So do I just leave the sock in the water for a week?
    Jan 2012
    7,264
    yup, as long as it ever takes. Squeezing it now and then speeds it up.
    Jul 2015
    Western NC
    115
    I just dumped 8 pounds of Clorox Stabilizer in the deep end.
    Some brushing was needed to get it to dissolve completely.
    It registered at the intended level on the test the very next day.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Sparkle View Post
    I'm glad it didn't cause you any problems, but we don't suggest doing this with many products, because the risk of staining or damaging a finish is high. Not a good plan with most products.
    Essential Links:
