Thread: PH and ta
    Jul 2015
    Whitewater
    3
    PH and ta
    My ta is 170ppm and my ph is 6.2. I have muriatic acid and borax how do I use them and in what order. I have a cartridge filter my first pool. Sorry if this is a dumb question. When people say added to the skimmer can I also do that even though I have a cartridge filter
    5250 gal round above ground cartridge filter
    Jun 2014
    15,221
    Re: PH and ta
    Hi and welcome! I would first focus on PH and raise by borax, soda ash, and/or combination of aeration. You want it at least at 7.2. The Poolmath calculator can help. Once your PH is over 7.2, then you can see what changed with your TA and start to "slowly" try to adjust it down a little while keeping the PH at its required range. This page: Pool School - Recommended Pool Chemicals can help you a bit as well.
    So adjust PH first, then TA. Always add chemicals near a return just with the pump on for at least 30 minutes. You might also consider reviewing these pages as well:
    Pool School - Chlorine / CYA Chart
    Poolmath calculator
    TFTestkits.net
    Pool School - Test Kits Compared
    Welcome!
    Jul 2015
    Whitewater
    3
    Re: PH and ta
    Thanks for your reply. I thought ta is the buffer for ph. On YouTube they say to get the ta in line before you mess with ph. How do I figure out how much borax to put in and do I broadcast it or dump it in the pool. Again thank you very much for helping
    Jun 2014
    15,221
    Re: PH and ta
    You are correct. TA serves as a buffer for PH, but your PH is so low right now you could cause damage to your pool or equipment. So I would increase that PH to a safe level first, then adjust them both slowly together. It takes a bit of time when they are separated by so much (back & forth), but it will work. You can use the Poolmath calculator to assist in amounts to use.
    It's always best to add chemicals slowly near a return jet with the pump running to help mix everything better.
    Jul 2015
    Whitewater
    3
    Re: PH and ta
    Thanks. You were very helpful
