Thread: Need a good dosing solution
    Jul 2015
    Zeeland MI
    18
    Just by glancing at this board I see the most common solutions do liguid chlorine dosing is either the liquidator or the Stenner pump. Is there any other options? Could someone point me to a post or site that compares the pros and cons of all the options? I like the idea of the liquidator separating the salts from the chlorine. Does anyone have a recommendation for my pool? (details in signature)
    15'x30' 54" deep Above Ground (Built July 2015)
    12,000 Gallons
    Ecco 22" Sand Filter
    Waterway 1.5HP pump model: SD-15-1N11CC
    Taylor k-2006 test kit
    Casey's Avatar
    SW PA
    10,446
    Re: Need a good dosing solution
    I manually dose every day or so. Good luck in your search and welcome to TFP.
