Thread: Splitting pump duty between skimmer and cleaner
    Mar 2015
    Patterson, CA
    12
    Question Splitting pump duty between skimmer and cleaner
    Quick question on run times... I understand that I do not need to run my pool pump for very long each day, but since the pump does double duty between Skimmer and Vaccum, I was wondering what you guys suggest for a normal amount of time for each.
    Pool is 15,000 gallons in an L'ish shape. I have a sand filter and Pentair Variable Speed pump. If one of the smart people on here wouldn't mind recommending a time + speed suggestion for skimming and cleaning, I would really appreciate it.
    Eric
    30,410
    Re: Splitting pump duty between skimmer and cleaner
    Experiment. Pump run time depends solely on what it takes to keep your pool clean. I would suggest you start with a total of 12 hours run time and back off until you find it unsatisfactory. Most folks use 1000 rpm to start
    Mar 2015
    Patterson, CA
    12
    Thank you for the quick response. My system has a 2 way valve that switches between skimmer and pump and I was trying to see if I should balance between the two (6 hours skimmer, 6 hours cleaner) or go half and half for 12 hours?
