Thread: Plumbing Mysteries
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    Plumbing Mysteries
    Now that I'm a chemistry expert, I've moved on to trying to fully understand the mechanics behind it all. I'm left with three outstanding questions about my setup (see associated diagram):
    1.) What is a relief & how does it affect me?
    2.) This pipe was labeled PF by the builder - I'm thinking "Pool Floor," but after reviewing the pictures I have of the trench, it's an independent line separate from "Pool Drain" in the lower left corner of the diagram. Is it possible they plumbed two lines all the way from the equipment pad into the main pool drain?
    3.) Why is this valve here & why is it partially closed? I have an elevated spa with a spillway into the main pool. While in pool mode, there is a small amount of flow into the spa through the jets, but clearly, the three-way valve after the heater is closed to the spa. Is the ball valve at #3 a way to balance the flow between the pool and spa through the check valve?
    Thanks for the insight!
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Jun 2015
    Wildomar, California
    423
    Re: Plumbing Mysteries
    First, the relief valve is so that you van adjust it so that some water flow will bypass the water flow and that allows you to set the flow over the WF to your liking. Valve 2 must be your main drain line. Valve 3, well, I don't see any purpose for it all all
    Sep 2014
    Cibolo, TX
    89
    I had a tech from the pool builder out yesterday for the routine maintenance provided under my first year warranty. When I asked him about #3, he told me it was to intentionally restrict the flow to the pool so that 75% of the water went to the spa & 25% went to the pool. This was to ensure proper flow over the spa spillway into the pool.
    Jun 2015
    423
    Yeah, that's what valve #3 is for. I should have recognized that.
