Results 1 to 7 of 7
Thread: Shock-level bleach and no way to move the water
    Jul 2015
    Austin, TX
    2
    Exclamation Shock-level bleach and no way to move the water
    I had just poured in enough bleach to bring my pool up to shock level, then while turning off the timers, the pump system broke. I am waiting for a callback from my repair guy, but in the meantime I am very concerned about what damage all that bleach will do if the water is not moving. Should I be concerned about this? Is there anything I can do until he gets here? What if I cannot get it repaired for several days? (FYI, I am a pool owner for only 2 months. I just joined TFP last week. It really helped me to understand the chemicals better & stay away from the pool store. I am not so good with the equipment yet.)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: Shock-level bleach and no way to move the water
    Brush it, brush it, brush it. But in this heat we've had, all that SLAM level bleach will burn off pretty quickly----- end of day probably. Got Test results for us? Welcome!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    was there any circulation at all? Even a few minutes is all it should take. A few times around with he brush and you'll be fine.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2014
    15,298
    You'll be fine. As mentioned above, brush and stir everything manually. If your FC is below SLAM level and it's just bleach, you can hop in the as well! No problem. Just don't wear your finest swimwear is all - just in case. Hope your pump gets resolved soon. Oh ... and welcome to TFP!
    Jul 2015
    Austin, TX
    2
    Thanks so much everybody. That is a relief! The pump was running well while I was pouring and for at least another 5 minutes before pump broke. I did some brushing as well. Thanks for your help! I apologize my signature did not come through. I must have forgot to commit. It should work in the future.
    15000 gallons, IG plaster, Hayward Pro-Grid DE, Pentair WhisperFlo 1.5 HP full rated single-speed pump, AquaRite SWG, Taylor K-2006, built 2007.
    Jun 2014
    15,298
    You got it Pete. It's showing now. Good luck, and have a nice weekend.
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    465
    Do you have a pool cover pump and access to electricity? If so, put the pump in the area you poured in the chlorine, and run a garden hose to the other end of the pool. You won't get any filtration, but the water will circulate.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 29k gal., 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
