Results 1 to 15 of 15
Thread: Amount of Decking
    Dec 2014
    Saugus
    8
    Amount of Decking
    Sorry to ask this question again but still trying to get a visual of roughly somewhere between 1000 and 1500 sf of decking.
    Budget is certainly an issue but .....can you folks share some input on how many sf of deck you have?
    I am almost at the decking stage now and would love some further input/pictures that demonstrate exactly how many sf of deck you have.
    Pool is going to be 22 x 38 free form
    I'm thinking a minimum of 4' on 3 sides and then coming back to the house with 12-15 feet for table, chairs, grill etc.
    Thank you in advance.
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    Re: Amount of Decking
    We are doing 703 sqft of decking
    Not a real pic but don't have it done yet! Lol
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Dec 2012
    Manassas Park, VA
    207
    after reading the forums for a few years it seems like the general rule of thumb is the more decking the better. In my case I have about 3' of deck where the pool meets the grass. This is an issue when I cut and trim the grass as it is hard to keep it out of the water which means I have to clean the pool after cutting the grass.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    Sep 2009
    Frederick County, MD
    185
    My suggestion has always been.....
    Figure out how much decking you want and then double it. Everything takes up way more room than you think.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    Jul 2014
    New England - MA
    310
    I have approx 1000 sq ft. Posting pics of deck work that was started today.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Pics of my 400sf deck in my build thread in sig.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    I have 1350 square feet of deck. It was basically all that would fit. My back yard is all pool and deck except a five foot planting area on each side and two tiered planting areas along the back. There is also an outdoor kitchen area and the pool equipment area behind a wall in one corner. The rest is deck. I left room for just enough plants to soften and provide a backdrop for the pool.
    In addition to the 1350 of deck, I have an additional 650 square feet of covered patio adjoining the pool deck, so I guess the total is 2,000 square feet. I wouldn't give up any of it.
    chiefwej
    May 2015
    Naples/FLORIDA
    82
    This is my pool design. I have about 1700sf of decking. This includes the covered Lanais that will flow into the deck as all one level and material (travertine).
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Ours is 1650 SF. The link in my signature will take you there.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Dec 2014
    Saugus
    8
    keep em coiming.....i love getting ideas from this forum
    Dec 2014
    Saugus
    8
    Quote Originally Posted by bmoreswim View Post
    Does the 1650sf include the walkway?
    I have about 3,000 square feet of travertine.
    The best way to see it all is the drone flight video I took. Click on the video
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Quote Originally Posted by heegs24 View Post
    No, just the rectangle around the pool. The walkway is about another 250.
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    Mine is a rectangle pool with sides of 9', 18' and two 4' lengths. We keep two chaise loungers, 3 Adirondack chairs, one table with 4 chairs and 1 zero gravity lounger on the deck. One 4' side is entirely taken up with the autocover box. Thankfully we made it big enough (because someone at work told me "get as much as you can, you won't regret it later" and it was true).GoogleHousePic.jpg
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The general rule for deck is as much as you can fit or afford. More is always better. But then I live in AZ and have an outdoor kitchen, dining area, and living room, as well as the pool loungers.
    chiefwej
