Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Pool Hydraulics-Solar heating. I want to do the right way first.
    Jul 2015
    Windsor, ON
    20
    First off, this is a great site. I have spent many hours reading various articles. Planning an 18' above ground and I hate a cold pool....
    I want to maximize the pool temp using only the sun. I have space on my roof for a 11.5' diameter collector of some sort. Leaning towards poly pipe. Before I looked into pool hydraulics I planned on running the entire flow from the pump through the collector and back to the pool. It is roughly 60' each way from the pool to the collector. (That includes 15' up to the 1.5 story roof.) I was thinking do 4-1/2" lines to the collector coil those until I reach my maximum diameter (11.5') and then return 4-1/2" pipes back to the pool. There would be no connections anywhere in the lines except compression at each end to eliminate a bottle neck. After reading the excellent articles by MAS985 it appears I'd need 10-1/2" pipes each way to the collector(insert big eye emoji).... What are your thoughts? Any help or suggestions are appreciated!
    I'll attempt anything.
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool Hydraulics-Solar heating. I want to do the right way first.
    You would do better and may save money by buying Fafco's simple system: Amazon.com: Fafco Solar Bear Economy Heating System for Above-Ground Pools: Patio, Lawn Garden .
    Its larger than you want but you may be able to modify it. You get most efficiency by moving a lot of volume thru the system with max exposure to sun. With half inch pipe you will move volume but not much exposure-- you need smaller pipe.
    I'm not sure how much the Fafco system costs in Canada. The simple fact is that most DIY from scratch solar set ups are not very efficient and move lots of water for not much heat gain.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    As is mentioned above you are way better off with a commercial panel, not only will it be cheaper than the materials cost of making a DIY system, it will outperform just about any DIY system you can build.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Please include a cost breakdown between DIY and Premade. When I was looking into this the cheapest premade system I could find was >$500 and I couldn't figure out how to spend >$200 DIY.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Apr 2013
    Sacramento, CA
    2,769
    The fafco product listed above is $289
    Jun 2014
    Uxbridge Ontario
    56
    We are in Canada as well and just ordered this one a couple weeks ago, looks very similar to the Fafco one linked to above.... only smaller to fit your needs... comes in many variations and was pretty easy to install.
    2-2 Garden
    I looked for quite a while for a cheap solution until we found this. They do have different sizes and variations... some systems come with 5 panels some with 10... look around to find what you need but they are very well priced and easy to install.
    5 year warranty too and can be left up in the winter as long as they are properly drained.
    21' x 52" Round Above Ground. (Buried 2') AquaPro 1HP pump, Jacuzzi 19" Sand filter, Hayward inline chlorinator.
    Hayward H200 millivolt NG Heater, SunQuest 2 x 2'x10' Solar heater.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    only issue I see is that it uses your pool pump. can't place it up on roof or really much off ground level I would assume.
    just priced a DIY from stuff at HomeDepot for less then 150. Guess it's just what you feel you can handle on your own. I like the warranty idea. So that might make a difference when I decide to do this for my pool.
    Jun 2014
    Uxbridge Ontario
    56
    We hooked ours up using a separate submersible pump only because our pool pump runs at night, cheaper on hydro to run off peak .
    We have solar panels on our shed to run the smaller pump we use for the solar heater but they don't have enough juice to run the pool pump.
    Eventually hubby wants to upgrade them and add a couple more batteries and then the pool pump can run of the solar energy and then run during the day but right now the solar heater is completely free
    We already had the submersible pump too though......
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Have him check into LiFePO4 batteries. I've been seeing a lot about those for green storage. No Lead-Acid batteries to mess with.
    Jul 2015
    Windsor, ON
    20
    First I want to say THANK YOU for all the great responses. My interest in prefab units over my own poly design is increasing. What I'm noticing is there is tons of different brands. Fafco, enersol, SunQuest, EcoSaver on and on. What are your experiences with any of these brands if any? Thanks in advance.
    Jun 2015
    Central, NJ
    566
    The Amazon link for the FALCO posted above by gwegan does not get very good reviews on Amazon site. Any reviews here on this product?
    The SunQuest does not have any reviews on Amazon, how is it working for you tmurpy? any reviews by someone that has had then for a few years?
    Isaac-1, How are your Techno-Solis panels doing? How long have you had them? How many do you have and what size? What type of temperature change do you get especially early spring and late fall?
    27,000 gals (20 x 40), IG, vinyl, Hayward Sand Filter S244T 300LB, Hayward
    Super pump SP 2607X10 1 hp.
    Jul 2015
    Windsor, ON
    20
    Update, I ran 100' of 2" poly from the pool location up to the roof. I'll need to use flex PVC to connect whatever solar I do. Its not too bendy....
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I am very happy with our solar setup. It works great and we get to swim more because of them. Details in my sig, pics in my build thread.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sorry for the slow response, my Techno-Solis is doing fine, it was installed about 1.5 years ago, to replace an old solar heating system that came down with the old roof the year before. We have another member here who installed Techno-Solis panels 6 or 7 years ago, and just reported his first small pinhole leak last year, he was able to patch the leak using plastic welding.
    Jul 2015
    Windsor, ON
    20
    Update, here is the plan.... 2" poly to and from the roof. 2 collectors each using 1500' of 1/2" poly (DIG brand from home depot). Each collector will have 3 lengths of 500' to minimize pressure drop. The surface area of each collector will be roughly 84sq'. Thoughts?
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Can't wait to hear the results!!
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by scottpanek View Post
    How do you get 84 sq-ft?
    It isn't the curved surface area of the pipe but the projected planer surface area (i.e. solar capture area) of the pipe which is 0.5/12 * 1500 = 62.5 sq-ft. And that is only when the sun is normal to the panels.
    Mark
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    What about side scatter and absorption within the tubing itself?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Insignificant. It is the direct solar incidence that matters and that is a plane wave so it is the planar capture area of the pipe that determines the solar gain.
    Forgot to mention though that when it comes to heat loss, then the entire surface area matters. So you will lose heat as though it is 84 sq-ft but the solar gain is still 62.5 sq-ft. That's why smaller tubes are more desirable and used in commercial panels.
    Mark
  20. Back To Top    #20
    Jul 2015
    Windsor, ON
    20
    OD of the pipe is .7", not .5" that's the difference. I understand that will only with the sun at the perfect direct angle.
