Thread: wrinkles??
    Jul 2014
    kamloops bc
    39
    wrinkles??
    Okay so I searched this on here and found dozens of threads, however the "dead horse" was mostly about how to remove. My question is if water imbalance is what can cause liner to wrinkle, what is the bad balance? The liner is about 10-12yrs old, the large wrinkle and one other showed up when liner was several years old, then this years after not opening pool last summer, there was additional ones?? They are on the slope closer to shallow end.
    14 x 28 IG, Hayward sand filter, Hayward 3/4hp pump, auto puck chlorinater,(used only when away) Hayward Natural gas heater, vinyl liner
    Casey's Avatar
    SW PA
    10,444
    Re: wrinkles??
    I'm not sure why liners wrinkle after they are installed UNLESS... you have had ground water issues which can happen even if you do not open the pool.
    Jul 2014
    kamloops bc
    39
    Re: wrinkles??
    I'm wondering if it is a water balance thing?? If possible what to watch for?
