Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 110
Thread: **UPDATE** NO LONGER Frustrated after drain and refill
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    Before I drained 3/4 of my pool water my chemical results were:
    FC: 1.5
    CC: 1
    Ph: 7.2
    TA: 190
    CH: 125
    Cya: 150
    Completed the refill and retested just now:
    FC: 1
    CC: 1
    PH: 7.2
    TA: 140
    CYA: 90
    I'd really hate to have to drain and refill again.
    What can I do?
    This is my first conversion to this method of chlorinating my pool.
    I've already removed the 3" tabs from my inline chlorinator and bought 10 jugs of bleach.
    **13 K gallons, in ground, rectangle, 14 x 30 Vinyl, single main drain, Sand filter, Hayward Tablet Chlorinator, Pentair Pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Frustrated after drain and refill
    You can manage your pool with 90 cya. Just set your chlorine level accordingly, Chlorine CYA Chart
    More here, Pool School - How to Chlorinate Your Pool
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    I can't, for the life of me, figure out what I should do to my pool at this point. I tried the pool calculator but I'm not comprehending the calculations.
    I have 8.25% bleach and Borax. I don't know how much I should add at this point.
    May 2014
    Cookeville,TN
    97
    What have you put in for pool volume in gallons? We need information about your pool to help. You should put the information as your signature; look above at pooldv as an example. Ask if you can't figure out how to build your signature or don't know what info. to include.
    7600 gallon; 18'X54" round; vinyl; sand filter and 110V pump, 2-speed.
    Near Cookeville, TN--1/2-way between Nashville--Knoxville along I-40; Highland Rim part of the Appalachian Plateau (we call the Cumberland Plateau for the southern half of this geological region).
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Marci Can you please put your pool info. in your siggy? It will help us help you. Here is a link to how and what do add.
    Pool School - Read This BEFORE You Post
    Once we have that info at a glance we can walk you through pool math. It can be overwhelming!
    HUGS we can help you!
    Kim
    ernie01jt's Avatar
    Mar 2015
    Smithton IL
    178
    wow, you guys are either up way late or woke up too early!
    18' x 38' 20,500 gallon vinyl IGP, 3.5 - 7' depth, Pentair FNS Plus DE filter,
    2hp Whisperflo high performance pump, 1.1hp boost-rite pump for the cleaner,
    250k BTU MasterTemp heater, LetroLegend pool cleaner, Hayward TurboCell GLX-CELL-15 chlorine generator
    Speedstir, K-1776, TF-100
    Jul 2012
    Tallahassee, FL
    30,464
    LOL woke up too early here!
    Kim
    DFW, TX
    24,485
    Here are some detailed instructions on using Pool School - PoolMath
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    I didn't know that my signature was not attached to my post.
    Jan 2014
    Buckeye AZ
    807
    Maybe asking the obvious, but this was a partial refill right?
    With a cya of 90 your initial liquid chlorine addition will seem high, but once that's in the pool, you are adding just what you lost each day, and that amount will be about the same at any FC level, 3-4 ppm.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Jan 2014
    Buckeye AZ
    807
    For your pool, to go from 0 fc to 12 would take 231 oz of 8.25% bleach. At sundown take another FC reading and put that in the now column, have 12 as your target, and add what it says to get back to 12. Repeat each sundown until you get the hang of it. If your sundown test ever show less than 7, you need to aim higher with your target.
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    Red face Re: Frustrated after drain and refill
    Ok, I figured out the pool calculator. I didn't realize that I should put in all the levels FIRST then calculate. I was trying to do one element at a time. DUH!!
    I can't wait to get home to start getting my pool in order.
    Stay tuned! Mahalo.
    Jan 2014
    Buckeye AZ
    807
    you can do one at a time, but others down the list will affect goals above. Did you select troublefreepool.com as the reference in the menu at the bottom? Put the current readings in in any order, but don't look at the recommended actions until you've done everything. If you need to SLAM, you would also need to manually put in the goal for FC.
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    BuckeyeChris-
    I eventually found where I could change my method to "Troublefreepool" instead of conventional. That made a big difference in the calculations.
    Not only am I am "challenged" pool owner, I'm also not the greatest with computers.
    Please bear with me.
    Jan 2014
    Buckeye AZ
    807
    Quote Originally Posted by Marci M View Post
    BuckeyeChris-
    I wish the page would default to that.
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    My latest calculations:
    FC: 2
    PH: 7.2
    TA: 150
    CH: 100
    CYA: 100
    I don't even know if I'm headed in the right direction.
    30,415
    Nor do I because i am not sure of the problem. Let's get a simple plan working. Tell us how your water looks.....we'll go from there. If you can post a pic that would be helpful, too.
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    My pool is clean and crystal clear, but my chemical readings are a mess!
    Reminder, this is a few days after >50% refill.
    FC: 0
    CC: .5
    CH: 100
    TA: 170
    CYA: 100
    I'm testing and re adjusting twice a day.
    I'm about a week into converting to "TFPC method".
    Last edited by Marci M; 08-02-2015 at 04:46 PM. Reason: Trying to add photo of pool
    Jun 2014
    15,078
    Okay Marci, let's take it one step at a time:
    1 - Your CYA is still quite high I know, that means another partial drain. Probably not what you wanted to hear, but 100 is simply too high. Unless you made a mistake in testing, but if the black dot disappeared too early .. it means partial drain. That has to be done before adding any more chemicals.
    2 - If it wasn't for the CYA, I'd say expedite bleach right away. O FC is dangerous.
    So try to reduce that CYA some more and then next set of readings, make sure you include the PH. That's very important as well.
    Recap:
    1 - Lower CYA (at least to 70-ish), 50-60 probably ideal though
    2 - After drain, add bleach right away with a target of about 8-9
    3 - Check/adjust PH to ensure it's between 7.2-7.8
    Those should be your first priorities.
    PS - Try not to let that CYA issue get you down too much. MANY of us went through the same thing before we learned TFP and realized what pool store products do to CYA. Now that you know, you'll be in control from now on. Mahalo!
  20. Back To Top    #20
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    "if the black dot never disappeared"
    Texas Splash,
    This part of your message confused me. My black dot disappears way too early, indicating a high CYA, right?
    I hope I'm doing the test wrong and I don't need to do another partial drain. (My husband is about to kill me over this.)
    Thank you for responding. Aloha!
