Thread: Stenner pump liquid measuement
    Dec 2014
    Riverside California
    482
    Just installed a Stenner pump with a gray 15 gal tank. Works great so far, but does anyone have a good method for measuring how much liquid is in the tank? I have dumped about 9 gals of bleach in so far, but would like to know how much capacity is remaining. I tried shining a bright flashlight into the fill opening but still cannot see how much is in the tank using the graduations on the tank. I suppose some kind of dipstick would be in order. Has anyone made one that is easy to use? Thanks.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Mar 2015
    Sugar Land , TX
    424
    Re: Stenner pump liquid measuement
    I use a rigid plastic tube that is as deep as the container. I can insert in the fill hole and can see when it hits the bleach. I can then tell how much is left.
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    I guess my method doesn't help. I have a translucent tank and can see the level, but still marked the side in 2 gallon increments.
    Support the site
    Dec 2011
    Prosper, Texas
    124
    you should be able to see the level as it gets closer to the top. My tank is blue so maybe its easier for me to see it, not sure. I also use the shake or lift method quite often to get some idea of whats still in it.
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    My Stenner tank hold 25 gal and I buy chlorine in 2.5 gal carboys. I made myself a dip stick from a garden stake by cutting a saw kurf in the stick after adding each carboy. Now it's easy to tell how many carboys the tank will hold.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by stev32k View Post
    I like this method. Kind of like the dip stick gas stations use to see what is in the underground tank.
    Support the site
