Results 1 to 7 of 7
Thread: Pump Run Time: I think I'm wasting $$$
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    I've read through the Pool School Determine Pump Run Time. It is general knowledge and I'm looking for help with something more specific..
    Roughly 17000 gallons in a kidney bean shape. I have a Hayward Ecostar Variable Pump. At some point I changed the settings for whatever reason and now I think I'm just wasting money.
    From the manual it seems as though there are 8 different timers plus four present Speed buttons:
    1. How long overall should my pump run?
    1a. My understanding was that this should run 24 hours a day due to the Variable nature
    2. At what speeds should it run?
    3. At what length of time should the timers run?
    4. Anyone know of an online calculator?
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump Run Time: I think I'm wasting $$$
    1. Minimum is 2 hours, maximum is up to you.
    1a. Not true and unnecessary
    2. Try 1000 RPM as see if that is good enough for the skimmers
    3. See #1
    4. For what?
    Mark
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by mas985 View Post
    3. See #1
    4. For what?
    Thanks mas985! I better get to experimenting and then seeing how much money I've lost :'(
    Patrick
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi fatboy,
    how long you need to run it really vaires from pool to pool.
    2 hours is a good start, 4 hours is usually enough for a lot of folks.
    If you have a lot of dust which blows every day, you may need to run your pump longer, for skimming purposes, than someone who love in Florida in a lush dust free environment.
    John Q Farmer with a wheatfield in his backyard in Iowa may well need to run it than the guy with lots of dust blowing in.
    see what I mean?
    Basically, its run it enough that keeps your pool skimmed and get some decent circulation. There really are no rules beyond that.
    Divin Dave,
    rolo918's Avatar
    May 2015
    Macomb mi
    95
    Get a flowvis it will tell u you. GPH. Then u can determine your run time
    FlowVis® Flow Meter - H2flow
    mas985's Avatar
    Pleasanton, CA
    11,737
    Gph and run time have little in common. Read pool school.
    Mark
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by Divin Dave View Post
    Hi fatboy,
    see what I mean?
    Thanks Divin Dave! I was really misled about this... Anyway, fix it now and don't cry about lost money that I can't get back right? I think I'll start with 4 hours because that's 20 hours less than what its been running at.
    Patrick
