Results 1 to 10 of 10
Thread: What do you think????
    Jan 2010
    Randleman,NC
    620
    Well,haven't been on here in a while.My liner ripp'd over the winter.So I drain'd the water in the spring&didn't do anything with it.Well,thinking about replacing the liner.Concern'd with the hard rain's we have had.Noticed the cove of sand is down.I'm thinking of just sweeping up the floor&going for it.I had such a bad experience the last liner replacement I did.Had alot of liner lap over on 2 side's of the wall.The bottom has a few low spot's in it .Should I just start from scratch with a level&some wood&rework the bottom.Any suggestion's.Also had a bead'd receiver.How hard is it to go with a pull over liner??Took a couple pictures.Thank's for any info
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jan 2010
    Randleman,NC
    620
    Re: What do you think????
    Could not upload pictures.Sorry
    Quote Originally Posted by kplaster View Post
    Well,haven't been on here in a while.My liner ripp'd over the winter.So I drain'd the water in the spring&didn't do anything with it.Well,thinking about replacing the liner.Concern'd with the hard rain's we have had.Noticed the cove of sand is down.I'm thinking of just sweeping up the floor&going for it.I had such a bad experience the last liner replacement I did.Had alot of liner lap over on 2 side's of the wall.The bottom has a few low spot's in it .Should I just start from scratch with a level&some wood&rework the bottom.Any suggestion's.Also had a bead'd receiver.How hard is it to go with a pool over liner??Took a couple pictures.Thank's for any info
    Jan 2010
    Randleman,NC
    620
    OK!!
    Jul 2015
    Neenah, Wisconsin
    10
    From what I hear be very careful in removing the old liner. Cut it into sections with a utility knife and then be very careful not to push and debris onto the sand from the bottom of the liner. That could potentially create some issues. Sweep up your cove and then level out the bottom (tie some cardboard onto your shoes to keep footprints from forming). Use a tamp to create a nice hard bottom and then proceed with the new liner install.
    Index 24'x52" Metal Frame Pool 14,700 Gallons - Overlap Liner over old liner - Doughboy Standard Skimmer - Hayward Perflex EC65 DE Filter w/ 1 HP Pump - Inline Trichlor Chlorinator for CYA addition, chlorination on vacations. Installation in summer of 2016.
    Jul 2015
    Neenah, Wisconsin
    10
    If you wish to change to overlap you'll need coping strips to hold the new liner in place. Make sure you have an even overlap before you start smoothing wrinkles? Then fill with water. Using a shopvac to help you smooth some of the wrinkles after that will help. Youll need something like a broom to push the liner against the cove as the vac doesnt actually smooth the wrinkles but help aid you in doing so. Perhaps someone can chime in on how to hookup the shopvac for this?
    Casey's Avatar
    SW PA
    10,461
    Jan 2010
    Randleman,NC
    620
    Thank's for info.Also.where is a good place online to order liner,etc.Has you can tell the liner that was in there faded.That wasn't even 5 yrs old.Got it online.I cant think of who I orderd from
    Casey's Avatar
    SW PA
    10,461
    I always Google 4 or 5 online sites n go from there. I got my liner from poolsupplyworld because I loved the pattern. But I found a liner for my brother by searching several sites n finding the best deal on a 25 mil/g liner with his design preferences in mind.
    Jan 2010
    Randleman,NC
    620
    I ordered the last liner was a fish design.Dark liner with alot of color.MISTAKE!!!!!..Don't know if it was a bad liner or BBB Method.Not sure.Thought about just going with a plan blue design this time.Found a couple sites that carry the beaded style.But only comes in 20 ml.Wondering if its worth the extra for the design&25 ml.
    Quote Originally Posted by Casey View Post
    Jan 2010
    Randleman,NC
    620
    Found what I was looking for.No difference between a 20 to 25 liner.Standard ML for AGP
