Results 1 to 15 of 15
Thread: Solar Cover Tips
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    Solar Cover Tips
    I've seen a couple other Solar Cover Tips threads but I don't want to bring back an old thread... I know some forums frown on reviving old ones.
    1. How will my readings be affected?
    2. Will I need more or less chlorine/muriatic acid?
    3. Will there be an issue with my Nautilus Dolphin running with the cover on?
    4. Am I making more of this than I should?
    1. Kidney bean shape
    2. Roughly 17000 gallons
    3. Will cut to fit
    4. Also purchased a reel
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Solar Cover Tips
    1. None
    2. Likely less chlorine usage if you opt for non-clear cover
    3. probably not...
    4. nah
    Dolphin E10 Cleaning Robot.
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by borjis View Post
    1. None
    3. probably not...
    4. nah
    Thanks borjis! I did get the clear because they had better reviews on Amazon...
    Patrick
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    right on.
    I had a really tough time deciding clear or not.
    After I got the blue cover I regretted not getting clear, but now I'm glad I went with blue.
    I'm saving about 2ppm of chlorine per day using the blue cover and I can always heat
    the pool with my solar panels. The blue does heat the top foot of water, just not
    as effectively as clear would.
    Jun 2014
    Northeast Alabama
    98
    I have a clear cover and this is my findings...
    > No water evaporation
    >Very little chlorine consumption & no change in pH with cover on
    >My auto vac runs just as well under the cover as it does without plus helps to mix the warm water throughout the pool
    I'm glad I went with the clear. It can change the temp of my water by 6 degrees in 24 hrs with good sun.
    Hope this helps.
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by layla2052 View Post
    Hope this helps.
    That helps a lot layla!!! Thanks so much for the info
    Patrick
    Jun 2014
    Northeast Alabama
    98
    You're very welcome! Good swimming!
    Jul 2014
    Hope Mills, NC
    567
    A cover wont affect the chemistry, but it will affect the temperature. Took mine off tonight and my pool water read 100 friggin degrees!
    Hate to think what that does to test results...
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jun 2014
    Northeast Alabama
    98
    I check the temp of the pool every day when I go out there to see if the cover needs to go on or come off because we like 82-84 degrees the best so I adjust the cover for that range. I use a 1/2" PVC pipe about 30" long to get my test water about 2 ft down every time I test so the warmer water near the cover does not affect my readings. I run the auto vac at least every other day to keep it all well mixed and has so far worked to keep the pool sparkling and the right temp for our purposes.
    Jul 2014
    Hope Mills, NC
    567
    It hasn't been below 82-84 degrees here in 3 months. Even without the cover, my water temperature runs in the low 90's.
    Vinyl in-ground
    1 HP Pump
    Hayward SWG
    fatboy1271's Avatar
    Aug 2013
    128
    Thanks for all the great info!!! I have extra PVC so I will use Layla's method for testing samples.
    Patrick
    fatboy1271's Avatar
    Aug 2013
    128
    These may seem like dumb questions, but...
    Should the cover be cut to the "exact" shape? In the picture below I've rough trimmed to let the cover stretch for a couple days per the instructions.
    Should there be no part of the cover climbing the walls and hanging over the top when I clean up the trim job?
    If I am to trim to fit does that also include the end that attaches to the reel?
    Patrick
    domct203's Avatar
    Jun 2015
    CT
    3,593
    I cut mine to fit within the pool, I was afraid that if we had a bad rain storm I'd have a few inches of un-sanitized water sitting in there. With it trimmed to fit the water will go in the pool and get chlorinated.
    Plus, I think it looks better LOL.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    Quebec, QC
    37
    My reel came with extension straps that attach to the solar cover with plastic plates and plastic screws. This gives you the leeway to cut an exact fit at the reel end of the pool.
    14 x 28 Jacuzzi vinyl inground pool, Jacuzzi Laser 250 sand filter, Hayward 1 HP pump.
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by domct203 View Post
    Dom
    Thanks Dom! I agree that this doesn't look good Plus I'm really afraid my dog will trip and fall on top
    Quote Originally Posted by Eauclaire View Post
    Thanks Eauclaire! Mine too came with straps, plates, and screws. I will cut it to fit this weekend
    Patrick
