Results 1 to 7 of 7
Thread: Light GFCI
    Jul 2015
    Santa Clarita, CA
    22
    Light GFCI
    Moderator comment - Moved from here: Pool Light is Tripping the GFCI
    Not to hijack but I am going through the exact same thing. I checked continuity on the lines out to the junction box thinking something may have shorted and did not show a short. So I am stymied as well.
    Thanks
    In ground concrete with pebble tech finish, with attached spa, Intelliflo Pentair VSD pump, iAqualink 2.0 Jandy control system, Pentair pool heater, Hayward salt chlorine generator and a Pentair 4000 series filter
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Pool Light is Tripping the GFCI
    Quote Originally Posted by Foreverlookin View Post
    Thanks
    Electrical shorts that a continuity test detects would show faults that trip a standard circuit breaker, not a GFCI.
    The type of leakage faults that trip a GFCI breaker are quite different and require a megohm meter ("megger") to detect.
    The OP has pretty clearly narrowed it down to an actual fault on the load side of the GFCI. If the FiberStar Illuminator is the only load, that, or the wires that feed it are the likely culprits.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jul 2015
    Santa Clarita, CA
    22
    Well housings are bad Pentair is replacing them under warranty.
    Jul 2015
    Santa Clarita, CA
    22
    Got mine working again and feel pretty stupid....when I changed the GFI I mixed up the neutral on the line/load side reversed them back and problem solved.
    Jun 2012
    western NY
    1,563
    How did the wires get mixed up in the first place if the GFCI was tripped before you replaced it?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jul 2015
    Santa Clarita, CA
    22
    Quote Originally Posted by danpik View Post
    When I replaced the GFI I was not paying attention to the line/load side of the neutral and had them reversed.
    Jun 2012
    western NY
    1,563
    Re: Light GFCI
    Never mind, I got confused thinking the problem you solved was the one the OP had. Got mixed up that there was two different issues going on in the same thread
