Results 1 to 15 of 15
Thread: Suction side chlorinator using needle valve
    Several years back there was discussion about using a fine needle valve threaded into a container with hose going from it to the drain plug on the suction side of the pump. I think Hayward made the valve that was able to be closed enough to allow adjustment for our use. I bought one, and never got around to putting it into use.
    Has there been anyone using this type of set up? Any problems they've encountered? I can't find much with search.
    Thanks
    Casey's Avatar
    SW PA
    10,438
    Re: Suction side chlorinator using needle valve
    Bumping to see if anyone can help you.
    22,548
    I used the Hayward needle valve on the LQ (Liquidator) and it worked very well. The adjustment is fine enough that you can dial it in pretty close. I don't know about hooking it to a tank with undiluted bleach in it, but I suppose it could work.
    Jul 2015
    West Tennessee
    6
    I tried this method for a while. The problem is you cannot easily judge the amount of chlorine being drawn in. "If I close the valve another 1/8 turn, does that mean 0.5 oz less or 0.025 per hr?"
    There are just too many variables that effect the outcome, i.e. ambient temp, condition of filter, skimmer accumulation of debris, etc.
    I pretty quickly moved to a Stenner pump where I have a constant, which is the rated or actual measured pump output, that I can use to calculate a reasonably close expected outcome. I know from measuring that the pump (10 GPD rated fixed) has an actual output of 1 oz per 53 seconds +\-, slightly higher than the .889 oz per minute rating. Using that constant (I realize the output may decrease as the tube ages) I can use the timer to deliver a fairly precise chlorine amount across as many time periods as I choose.
    Right now I have the pump delivering 50oz of chlorine in each of two separate main pump run times. During the past few days with 100 degree heat the minimum FC level has been a constant 5-6 PPM. Just right for the 45 CYA level.
    I can easily adjust the chlorine delivered by + or - the length of time the Stenner runs and know I can get an expected result.
    20,000 gal IGV 18x36x6 with 4' radius, Pentair Ultra Flow 1hp, Pentair CC75 cartridge filter, Stenner 45MP2. Built 2003.
    Chemistry teaches us that alcohol is a solution. That figures, as I have solved many of the world's problems while drinking!
    Thanks.
    Bama, I wasn't aware you were using it with a liquidator. I have the valve, I guess I'll experiment with it.
    Dec 2014
    Riverside California
    482
    Quote Originally Posted by rocketo View Post
    Exactly why I went with the Stenner, fixed output. Interfaced to my Easy Touch with Screen Logic I can adjust the Stenner time from my PC with a couple of mouse clicks.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    rocketo, did you use the hayward needle valve?
    Jul 2015
    West Tennessee
    6
    I did not, so my experience may be skewed somewhat. I used this one from USPlastics http://www.usplastic.com/catalog/ite...2220&catid=956
    Maybe the problem is the 2.5 tip does not allow enough control.
    I was hesitant to spend the $$ on the Hayward for an experiment.
    Ok, thanks. Yeah I tried that one too, no go. I've got the hayward, so I guess I'll try it.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    A stenner pump is the way to go. As to drawing chlorine into the suction side of the pump, I would not do this with any tablet feeder as the pH level will be very low.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Thanks, but to be clear, the system I was talking about was for sodium hypochlorite injection, not pucks or dissolved di-chlor.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by Rangeball View Post
    But even liquid injection will cause a pH reduction at the injection point. While the use of liquid chlorine products is generally a pH neutral process there is a lowering when the liquid is added and it is raised again when the chlorine is "consumed" - thus net neutral.
    I would think that suction side additions would cause a lowering on pH in the pump/filter, but how much would take Chem Geek to calculate.
    Support the site
    JoyfulNoise's Avatar
    May 2015
    13,201
    User mas985 (Mark) has a link in his signature to his own DIY Injector setup. Mark also did all the calculations for FC and pH rise and discovered that if you tune it properly, you will be perfectly fine.
    Cheers,
    Matt
    Matt
    True, but I run my pump 24/7 and my daily injection would only be 60 oz, so a very small dribble that should have a really low impact.
    Also, as pointed out, Mark uses a similar set up for acid injection and hasn't noted any low PH problems.
    Thanks. I've been through that thread a million times, even participated in it originally, I think.
    May 2015
    13,201
    Ooops, sorry, I misunderstood your question
    pH changes due to hypochlorite injection should be minimal. Just to be clear, when sodium hypochlorite is add to water, the reaction produces hydroxyl ions (OH-) and the excess lye in the bleach also contributes hydroxyl's so the initial effect is to slightly raise, not lower, the pH. See chem geek's Pool Water Chemistry Post #3. Given the high flow rate of water into the wet end of the pump, I would imagine the pH rise would be minimal at best. As long as you can ensure adequate shut-off with a needle valve so that there isn't a constant source of hypochlorite when the pump is not running, it should work very well.
    Matt
