Thread: Magnatek spa pump on Intex pool
    Jul 2014
    Llano, TX
    75
    I've got a Magnatek spa pump of unknown size sitting around and an extra whole house cartridge water filter. Does anyone know if these would work as a temporary setup for an Intex 16x48? I have my pool hard plumbed with through wall skimmer, but I can not stop the leaks at the Intex pump. I have to add 2-3" of water ever 5-6 days. I'm not looking at making this change permanent, I just want to the leaks to stop until I can get a suitable upgrade of pump and filter.
    Intex 16 x 48 Ultra Frame, Hayward 1HP pump/Hayward 180T sand filter
    Through wall skimmer, hard plumbed, homemade fountain. To do: keep working on deck, liner during the off season.
    Build thread, in progress: http://www.troublefreepool.com/threa...e-pool-install
    Casey's Avatar
    SW PA
    10,423
    Re: Magnatek spa pump on Intex pool
    I am not sure if it will work. Lets bump your thread n see if we can get you an answer.
    Jul 2014
    Llano, TX
    75
    I'm pretty much certain the pump can handle it, I'm mainly concerned about the filter handling it without filtering out the chlorine. Now that I start thinking I wonder if the Intex cartridge would fit in the housing I have. The things that make you go hum?
