Thread: muratic acid question
    May 2015
    Pahoa, HI
    16
    Good morning,
    I received my 2 gallons of muratic acid. It appears to be a construction grade, designed for cleaning tiles. There is nothing on it about pool use or % or active ingredients.
    Is this going to be ok to lower my pH? I don't want to add anything without checking with the experts first. Once bitten...
    Mike
    90,000 gallon, in-ground, 3 pumps / sand filters, in-line chlorinator on #2. Learning on the job!
    Aug 2013
    Arab, Alabama
    422
    Re: muratic acid question
    Does the container say 20 Baum? If so, that is 31% HCL...
    39YO 13K gallon former SWAMP/MONEY PIT, concrete bottom/Fiberglass Walls, Ecotech VS pump, Hayward Sand Filter, Dolphin DX5 Plus, Loop-Loc safety cover and YES, I have a TFT-100 test kit!
    Shock Level and Maintain - CL/CYA Chart
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    A brand name may help as well
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    May 2015
    Pahoa, HI
    16
    Klean-Strip 1 gal. Green Safer Muriatic Acid-GKGM75006 - The Home Depot
    apparently, based on the reviews: This stuff will work however you will need to use twice the dosage. Most muriatic acid dosages are based on ~30% concentration of acid, this stuff is ~14%. It will work just be aware its very weak acid concentration.
