Thread: Cloudy water with perfect levels...?!?!?
    May 2015
    Enumclaw, Wa
    60
    Exclamation Cloudy water with perfect levels...?!?!?
    Hey guys I need some help! First water problem in two years...
    Went out and looked at the pool today and my brother and his buddies left pool toys in the pool so the pump was running half dry.
    While taking stuff it out I noticed the water isn't sparkling it is cloudy and there's little particles in it. So I ran for my tf test kit and evening looks good.
    FC - 4.5
    CC - 0.0
    PH- 7.8
    ALK- 90
    CYA- 55
    Salt-3200
    Borats- 40
    Hardness-50
    Little history- we accidentally left the hose on all night a week ago, I back flushed the next day(smelt really bad). And I was slowly getting the cya back up, that's why it's a little low.
    Where do I go from here?
    Thanks, Brannon
    15x30 AG 12k, Hayward Matrix 1 1/2 hp, 21' sand filter, Pentair Mastertemp 400 propane heater. Intex swcg, Wanda the whale, upgrading to an Suntouch with Solar Bear Panels...
    Jun 2014
    15,221
    Re: Cloudy water with perfect levels...?!?!?
    It's very possible that during that unfortunate time when CYA dropped, your SWG was not able to keep-up with the sun and FC dropped thereby allowing algae to begin (cloud). I would suspect a SLAM is in order. In your case, hopefully it would go fairly quickly, then you could bump you CYA back up to the 70s and press-on.
    May 2015
    Enumclaw, Wa
    60
    Perfect, I will do, should I raise levels to mustard algae level since I don't know what kind of algae it is?
    Thanks, Brannon
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    No, regular shock level is fine.
    May 2015
    Ann Arbor, MI
    30
    It does sound like a SLAM situation, having had the same happen to us (leaving hose on overnight and cloudy water the next day). We are currently refilling with well water after a complete drain and I am AMAZED at how disgusting the pool water looked after the first night. I dumped in a small amt of chlorine (since there was no CYA not much was needed to SLAM 1/4 of our pool's volume), and the water is much clearer and particles are settling out rapidly already.
    That said, we had an issue sounding like this last year too (not an overflow or refill situation), and it turned out to be our DE filter. The pool was colorlessly cloudy (vs the overflow/refill cloudy, which was greenish yellowish brown). There was a rip in one or more of the sleeves for the filter's fingers. Some of the filter media ended up getting through the filter and became more or less suspended in the pool water, giving us perfect chem levels but cloudy water. I see you have a sand filter... Any DE in there too? We cleaned our filter thoroughly and replaced the ripped sleeves, and it cleared up within a day.
    Good luck!
    30,000 gallon in-ground marblelite pool, built ~1968, 18x37
    Hayward Perflex DE Filter, EC-65 (or 75?)
    Hayward Super Pump, 1 HP/230V, 2013
    Aquabot G-Jet, well water, Taylor TF-100 test Kit
    Renovation of marblelite and retiled in 1999
