Thread: Intex SF15110 bearings
    Jul 2015
    elk grove, il
    3
    Does anyone know the size or PN for the two bearings on a SF15110 motor? Motor seized up - bearings fried. I have it completely apart and they look to be similar to in-line skate bearings. Any help / info would be greatly appreciated!! (I scanned thru other threads but did not find a specific ref to the bearings)
    Ellington, CT
    262
    Re: Intex SF15110 bearings
    According to this video they are 6000RZ bearings
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Jul 2015
    elk grove, il
    3
    I saw that and ordered them - too big. I believe the 6000RZ is the next size up motor from mine. Thanks for replying. I am still scouring the inline skate shops trying to find the right size. Will post once I know for sure so anyone else with same issue can get 'er done!
    Jul 2015
    elk grove, il
    3
    I found the correct size bearing for the Intex SF15110 pump motor. Look for a bearing with "608" in or as part of the part number. I used inline skate bearings made by Labeda (ABEC-5) and the pump is smoother and quieter than when I bought it. Also found a 'basic' bearing at my local Ace Hardware if you cannot get skate bearings. These were noted as PN '608Z'.
    Hope this helps others with Intex bearing issues for this model number. Will be switching to a better pump during the off-season.
