Thread: can you fill the Chlorine bottle to 5 mil rather then 10
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    So Im slamming
    I have high CYA 80 (SWG)
    I thought I read somewhere when its high Chlorine levels you can read at 5mil and double it, saving form using 10mil and more drops
    Or am I just going to eat up all of my chlorine test kit
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: can you fill the Chlorine bottle to 5 mil rather then 10
    Hmmmm... interesting idea. I don't know the answer but it would be interesting and useful if you tried it at the same time and see how the results look?
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by YippeeSkippy View Post
    Im thinking about trying it tonight
    My slam level is 31 with the high CYA right now
    Ill post when I get it checked
    I swear I read somewhere that this will work
    --- Greg----
    Jan 2014
    Buckeye AZ
    807
    the accuracy goes down, I think is the issue, so if you're going to do that, set your target FC a bit higher to compensate for testing error.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Donldson's Avatar
    NW Ohio
    2,893
    Yes, a 5ml sample will result in a reading equal to 1ppm per drop. In the middle of a SLAM this is fine, but make sure when you perform the OCLT that you use the 10 ml sample for both the before and after readings.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Makdaddy's Avatar
    Jul 2012
    119
    Quote Originally Posted by Donldson View Post
    Cool
    I will see what happens tonight when I get home
    I just checked the TFT site and R-0871 (2 0z) FAS/DPD Reagent is only $10 or so
    I may just order extra if I get too low
    Hope this slam dosent take too long
    --- Greg----
