Thread: Need advice!
    Jul 2015
    Rebecca GA
    2
    Need advice!
    Bought Intex 26 x 52 ultra frame pool set. Came with Krystal Clear 633T cartridge filter pump. Bought a Hayward Wanda the Dolphin pool cleaner. This did not work at all with this pump. I was advised that my filter is too small for this cleaner. It was suggested I buy the Intex pool cleaner and was told this should work. Has anyone purchased this pool w/pump set? And have you purchased a pool cleaner that works with it? Didn't want to buy a new pump just yet. Just a cleaner that will work with this pump.
    26' x 52' Intex Ultra Frame AG vinyl pool w/ Intex Krystal Clear 2500GPH Filter Pump w/timer. 14,000 Gallon water capacity. Pool is filled by well.
    Casey's Avatar
    SW PA
    10,421
    Re: Need advice!
    Welcome to TFP.
    I'm sorry to be the bearer of bad news but you will play heck trying to fins a vac to vac your pool unless you modify your pool with a new pump, filter and skimmer box. Then you can buy a telescopic pole and manually vac your pool or use Wanda.
    I'm sorry but Intex is selling these pools with the cheapest pump/filters they can get away with.
