Results 1 to 10 of 10
Thread: Shock
    Jul 2015
    washington, pa
    8
    Shock
    I have a 30 ft above ground pool. I've added shock the many different ways I've been told. Broadcasting over the pool, in a bucket of water. In the morning I always have piles of it laying at the bottom of the pool. Pump running all night and a few sweeps with the brush before I go to bed. Can I add shock to an old sock like I add the stabilizer? Would that help?
    Jun 2015
    Raleigh
    357
    Re: Shock
    Why are you adding shock at all? TFP pools promotes bleach as a sanitizer and the SLAM method to eliminate algae for good. Shock will raise your CYA over time reducing chlorine effectiveness.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Shock
    Welcome to the forum.
    I agree with robertmee, if you're doing things right most of the time the only thing you will be adding is bleach. How are you testing your water? Have you read pool school at the top of this page?
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    Jul 2015
    washington, pa
    8
    Re: Shock
    Laundry bleach? Won't it stain my liner? How do I add that and how much?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Shock
    Yes, plain old laundry bleach, no additives. No, it will not stain. How much depends on the results of your testing. How are you testing your water?
    Jul 2015
    washington, pa
    8
    Re: Shock
    With the strips they gave me. Everything else is fine. Always losing chlorine.
    I already have the shock...can I use it in a sock and then use the bleach the next time?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Re: Shock
    I'm sorry to tell you this but strips won't hack it here. You need a proper test kit to follow the methods here. It will save you a lot of $$$ in the long run. Either the TF-100 (ww.tftestkits.net) or Taylor K2006 (Amazon). The TF-100 is a better value. Until you get a set of test results with one of these two kits we can't tell you how to proceed. We need a starting point in order to give valid directions to the destination.
    Losing some chlorine is normal. You lose it from sun and/or algae in the water. Stabilizer (Cyanuric Acid or CYA) take care of the sun. The remaining chlorine takes care of any algae. Usually. But if the chlorine level gets too low algae grows and then you wind up using a lot of chlorine.
    If you add the shock you're probably adding to something besides FC. I don't know because I've never added "shock" to my pool. I'd stick with plain bleach until getting a test kit and a good set of test results. Until then, start reading up in "pool school" at the top of this page. Knowledge is power.
    Jan 2014
    Buckeye AZ
    807
    Re: Shock
    having concentrated powdered shock laying on the bottom of the pool is more likely to stain than slowly adding a few cups of liquid chlorine (or...bleach. which is the same thing).
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: Shock
    What are the ingredients of the shock you are trying to use? Most pool shocks dissolve very quickly and shouldn't be piling up on the bottom of the pool. Leaving undissolved shock on the liner will damage it. TFP advocates using liquid chlorine either the 10-12% concentration from the pool store or 8% sold as bleach from the grocery store, and we also urge pool owners to invest in a high quality FAS/DPD test kit. A good test kit is an investment in the life of your pool. Without reliable results from a high quality test kit you are only guessing at what your pool needs to stay balanced. Test strips are very unreliable. They do not give the precision needed to determine how to dose the pool. On a strip it gives a range result. Is the CYA 30 or 50? Is the chlorine 5 or 10? It makes a difference!
    Love TFP? Become a
    TFP Supporter!
    Sep 2013
    Connecticut
    728
    Re: Shock
    Quote Originally Posted by kellyrenee16 View Post
    If the word "bleach" is bothering you, take a look at a jug of official liquid pool "shock" next time you're browsing among the pool chemicals. It's the same thing as laundry bleach, except for the fact that the liquid pool shock is more concentrated.
    At the end of the swimming season, any left-over liquid chlorine from our pool chemical supplies goes up to the laundry room; we dilute it half and half with water to get down to the familiar laundry strength.
    It's all the same stuff!
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
