Thread: Water behing liner at steps!!!!
    Mar 2013
    TN
    178
    Is it possible for water to leak at a jet on my steps and get behind the liner??
    I have had the pool installers out twice and the last time they "fixed" it it lasted two days until it was back like it was. I think I am going to try and pump the water out myself this afternoon and maybe do a dye test to see if it is coming from around the jets.
    Yesterday I felt of the jets and they were not tight against the liner. I made 3 to 4 turns on each one of them. I am almost at wits end with this issue.
    Any ideas or hints as what to try?
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: Water behing liner at steps!!!!
    Any idea what they did to "fix" it? It does sound like there is a sealing problem.
    Kim
    Mar 2013
    TN
    178
    Quote Originally Posted by kimkats View Post
    Kim
    it appears all they did was suck the water out and reattach the liner, which I had to do again last night and it looks as it did the day they left.
    I just do not know how to track down where it is leaking.
    Jul 2012
    Tallahassee, FL
    30,444
    So the next time you talk to them tell them you want them to find and FIX the problem that is causing this.
    I have NO real ideas BUT I have to wonder if the liner by the jet is too loose/big/does not fit right around the jet head. I wonder if there is a gasket that can be put on the liner before you put the jet head back on?????
    I am just thinking out loud to see if any thing helps.
    Kim
