Thread: Slowly going green, advice wanted please
    Jul 2015
    wisconsin
    1
    Hello, Just a little background. We purchased a 18x52 intex 3 years ago. I realize now that my test kit was not proper at that time, and honestly neither was my pool stores. My pool 3 years ago went this aweful green. I tested and had my pool store test it, and both test showed my numbers were great. They told me that a little green was not going to hurt. Well it was AWEFUL, no one wanted to swim.
    Fast forward...after that ordeal we finally put it back up this year. I found a proper test kit TF-100, but I'm starting to go green again, and I'm in panick mode. I would really love some help figuring this out. I also feel incompetent when it comes to the pool calculator...I guess I don't fully understand how to use it
    Anyway here are my numbers
    FC 4.5
    CC .5
    TA 300 This number blew my mind
    PH 7.6
    CYA 40
    Please let me know if I need to supply any additional information. Thank you for your time!
    18x52" Intex Above Ground w/ Sand Filter
    TF-100
    Jun 2014
    15,130
    Re: Slowly going green, advice wanted please
    Hello and welcome! Glad to hear you got the best test kit out there. So let's get started:
    - Green means you need to SLAM: Pool School - SLAM - Shock Level And Maintain. You must follow those directions carefully.
    - Important for SLAM: Lower PH to 7.2; your CYA is fine; and stock-up on regular liquid bleach.
    - You will use the Pool School - Chlorine / CYA Chart and Poolmath calculator during your SLAM, so keep these handy.
    At the same time, be familiar with Pool School - Recommended Levels and Pool School - Recommended Pool Chemicals once you pass your SLAM process.
    If you have any more questions, please let us know. Also, take lots of pics before, during, and after the SLAM! You'll be amazed.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,493
    That is a big TA number. Test your tap water to see what it is and get some more test practice just in case. There are also links to videos of the tests on TFTestkits.net.
