Thread: Added 58% Calcium Hypo - pool went cloudy
    Jun 2015
    Montgomery, NY
    27
    The pool has been on the Clorox bleach only diet for about 5 weeks. It looked great. My CH was at 225 and I want to get it up to 300/350 range. Since I have several left over pounds of Calcium Hypochlorite 57.8% I thought I would just use that for a few days instead of Clorox to treat the pool and raise the CH. I only added 2 lbs and while I can still see the bottom of my pool it went cloudy for about 24-36 hours. Is that to be expected since it really hasn't seen anything but bleach for 5 weeks? Also, is there CYA in Calcium Hypo? Thanks.
    20'x40'; 30,000G outdoor/in-ground; Gunite/Plaster (May 2005); DE Waterway 60sf grid (grid new'13); Pentair WhisperFlo Model WFE-28 2hp; TF-100 w/SpeedStir; 1 main drain / 1 main return; 2 skimmers; 3 in-line wall returns; RayVac cleaner; Manual 7-mil clear solar cover; morning & afternoon sun 'till 3:30 pm; Then shade; Well - no restrictions;
    Aug 2014
    Shallotte, NC
    693
    Re: Added 58% Calcium Hypo - pool went cloudy
    Probably, Calcium Carbonate?
    Jun 2015
    Montgomery, NY
    27
    This morning I'm at:
    FC = 14.5
    CC = 0.00
    pH = 7.8 (I'd like to lower it, but I don't know if accurate due to high FC)
    TA = 170
    CH = 225
    CYA = 30
    Aug 2014
    Shallotte, NC
    693
    Yep, probably a cloud of calcium.... you really need to get that TA down, some....probably by half or more. Why so high a chlorine level? You can be pretty sure that the pH is not accurate and won't be until your Cl is below 10.0.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,027
    Pretty common phenomenon.
    Jun 2015
    Montgomery, NY
    27
    Richard thanks for the link. I should have figured it would be out there...I'm sure there's not much you guys haven't seen by this point.
    ewkearns...TA too high? Okay. I just remembered that I typically target 150 bc the "pool store" kind of set that number in my head years ago. I now see it should be in the 70-90 range. Regarding pH though; once it FC comes down tomorrow or next day...is 7.8 okay for plaster as it notes on recommended levels; or I see a lot of forums where people are targeting more the 7.2 range.
