Thread: Maintaining pool while away for a few days - TFP method?
    May 2015
    Mississauga
    29
    This weekend I will be away for approximately three days. I am leaving Friday morning coming back late Sunday night. I am not sure what to do in terms of keeping the pool up and running while I am gone. I don't want to shut off the pump for three days as the pool will get filthy so I plan to run it, but in terms of chemicals, I plan on cleaning the pool and adding my chlorine on Friday morning but should I maybe bring the chlorine up to shock level before I go? It will be a warm and sunny weekend and I am sure that the chlorine will burn up over the three days I am gone. I do have an automatic chlorinator on my system but I don't use it. I could, but the pucks would mess with my CYA and I have it where I want it now (its at 40). Any thoughts?
    11.5K gal, IG vinyl, 3/4 HP Hayward Pump, Hayward sand filter, Hayward Chlorinator (Turned Off), Raypak Heater, Taylor FAS-DPD K2006C T/K
    Mar 2015
    Upland, CA
    222
    Re: Maintaining pool while away for a few days - TFP method?
    It shouldn't cause too much problems for your CYA to use pucks while you're gone. If you lose 2 ppm FC per day, pucks will only add about 3.6 ppm of CYA over the weekend.
    With a vinyl pool calcium levels are less of a concern than with plaster. You could also look into CalHypo pucks. They're more difficult to find, but I've seen them. It would only raise your calcium levels by 4 ppm.
    20k gal. IG plaster w/spa. 2 HP Aqua-Flo "A" pump, Hayward DE6020 filter. "The Pool Cleaner".
    Jun 2014
    Northeast Alabama
    98
    I know that my pool consumes 1-2 ppm FC per day, depending on full sunlight and amount of tree debris dropped in the pool. When we go out of town for a long weekend, I usually factor 2 ppm per day I'm gone plus 1 for good measure and the pool tests just under the top of my scale when I return. I make sure it's brushed & vacuumed well before leaving & do it again as soon as I return. Almost like I wasn't gone....
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
