Results 1 to 7 of 7
Thread: Warm evening
    Jul 2015
    Santa Clarita, CA
    22
    Warm evening
    Nice night for a swim!
    In ground concrete with pebble tech finish, with attached spa, Intelliflo Pentair VSD pump, iAqualink 2.0 Jandy control system, Pentair pool heater, Hayward salt chlorine generator and a Pentair 4000 series filter
    Aug 2014
    Northern IL
    4,615
    Re: Warm evening
    You should probably put some water in that pool !!! I read somewhere about pools floating from being empty. Just saying.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Warm evening
    Quote Originally Posted by MarianParoo View Post
    hee hee
    Jun 2014
    15,158
    Re: Warm evening
    Very nice!
    Ncdamsel's Avatar
    Jul 2015
    Garner ,NC
    65
    Re: Warm evening
    Wow.......that's beautiful
    13,995 gallons 24 X 52 / above ground pool.../.SWG/ sand filter/ vinyl liner
    Re: Warm evening
    Where did the water go?
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    Jun 2015
    Atlanta, GA
    640
    Re: Warm evening
    Oh wow!!
    12K Gallon IG Lap Pool (c. 2001)
    6.6 ft x 48 ft/White Plaster/Concrete
    Pentair Superflo VS Pump 2.0 HP/Sand Filter
    Dolphin S300i Robot/SolarBreeze Robot
    TFT-100 Test Kit
