Thread: URGENT!! Draining pool
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    I'm in the process of draining and refilling my pool to lower my CYA. It took longer than I thought to drain it.
    I have a vinyl pool. Would it be okay to leave my pool half empty till I can refill it tomorrow? (Approximately 12 hours)
    Will the integrity of my pools structure be compromised without the weight of the water holding it up?
    13 K gallons, in ground, rectangle, 14 x 30 Vinyl, single main drain, Sand filter, Hayward Tablet Chlorinator, Pentair Pump
    Aug 2014
    Northern IL
    4,615
    Re: URGENT!! Draining pool
    No absolute guarantees without knowing your water table, but the odds are in your favor that you will be okay if there is still a foot or so of water in the shallow end. Can you leave your refill hose on slow and check mid-way through the night?
    Jun 2014
    15,233
    Yeah, I would suspect that by only going to halfway you are just fine. Good luck with that CYA and let us know how it turns out.
    Marci M's Avatar
    Jul 2015
    Kapolei, Hawaii
    92
    Update: pool is refilled with no incident. I'll will test cya when I get home from work.
    Thank you for your responses.
    Aug 2014
    Northern IL
    4,615
    Excellent! Thanks for letting us know.
